cleat
Got another one. A 416 this time.
lynnmor
3 hours ago, cleat said:
Nope, not even close.
Looks like you need to jump start your OCD, the 25 fuse is in backwards and there is a debris on the fuse block.  -_-
  • Haha 2
cleat
Ha Ha
That will be fixed when the wire harness is officially installed.
Handy Don
Mighty glad to hear that! ;)
cleat
Transmission dipstick tube ready to be installed.
407882159_Transmissiondipsticktubereadytobeinstalled.JPG.64916cf89ddf52c6e8bf0bb7716fa2ae.JPG
Transmission dipstick tube liquid Teflon applied.
959027709_TransmissiondipsticktubeliquidTeflonapplied.JPG.74df52b51f044c5cf11d6dbcaab22e71.JPG
Transmission ready for tube to be installed.
Transmission tube screwed in then tightened using a 7/8" crowfoot wrench, extension, and ratchet.
Transmission dipstick and silicone grease ready to be applied.
2064005263_Transmisiondipstickandsiliconegreasereadytobeinstalled.JPG.14d889622c328d9f271de8b4dc74c998.JPG
Transmission dipstick silicone grease applied to rubber seal.
1328537018_Transmisiondipsticksiliconegreaseapplied.JPG.daa2dc9018356130838ae412d974d6b7.JPG
Transmission dipstick installed.
  • Like 6
cleat
Hydraulic valve control handle assembly ready to install.
1706556206_Hydraulicvalvecontrolhandleassemblyreadytoinstall1.JPG.8e03fee3fab094dfc350daec2741db0e.JPG
1693822592_Hydraulicvalvecontrolhandleassemblyreadytoinstall2.JPG.716e809dbf82ea1c9f268ab5ca2b8e46.JPG
1907620597_Hydraulicvalvecontrolhandleassemblyreadytoinstall3.JPG.2dabeb3d0b3712baf228f017406631d0.JPG
Tractor ready for Hydraulic valve control handle assembly to be installed.
1527776911_TractorreadyforHydraulicvalvecontrolhandleassemblytobeinstalled.JPG.e7da908b6d33bd76064c412e0b9397c5.JPG
Hydraulic valve control handle 5983 nyliner bushings installed.
370947360_Hydraulicvalvecontrolhandle5983nylinerbushingsinstalled.JPG.856a4cfab09eed230a65ba5a98960a81.JPG
  • Like 4
cleat
Spirol pin partly installed into the control rod bracket after a light coat of never seize was applied.
Make sure pin is installed just almost to the point of entering the center hole but not quite.
Towels placed down to protect paint.
Hydraulic valve control handle slid through top nyliner then control arm slid on.
1288115980_Hydraulicvalvecontrolhandleslidthroughtopnylinerthencontrolarmslidon.JPG.48997a8987864af714bd91a9e80e5014.JPG
Control arm aligned to hole in control handle then a screw of proper diameter was installed to locate proper location.
1077786391_Controlarmalignedtoholeincontrolhandlethenasrewofproperdiameterwasinstalledtolocateproperlocation1.JPG.c9aa6834fb9704f4836e669502a4423f.JPG
740472582_Controlarmalignedtoholeincontrolhandlethenasrewofproperdiameterwasinstalledtolocateproperlocation2.JPG.1b7818e90d9ef7a88ce29726f55ea144.JPG
Control arm spirol pin pushed in using vice grips.
Do not hammer pin in because that may damage the nyliner bushing.
362197250_Controlarmspirolpinpushedinusingvicegrips1.JPG.7c0e4f3be4f88d7d3b4755893d9104dd.JPG
983368547_Controlarmspirolpinpushedinusingvicegrips2.JPG.fcc0f206b11e4313f397844b5e65b15c.JPG
Lift bar and pin ready to install.
Lift bar and pin installed.
Control rod bracket ready to install.
Control rod bracket installed.
Make sure it is in correct position to hold handle down when installed.
I also put a little grease on the control rod where it passes through the control arm.
Control rod spring ready to install.
Control rod spring installed after a light coat of never size applied to control rod threads.
Spring nut tightened just enough to eliminate free play but ensure spring does not bottom out when control handle pushed fully forward.
Hydraulic valve assembly fully installed.
903994906_Hydraulicvalveassemblyfullyinstalled.JPG.d27d400aaa0d072daa79e0fbe3ffc66e.JPG
  • Like 4
cleat
Fuse block contacts cleaned.
Fuse block contacts greased with white lithium grease (that grease will be used on all wire harness connections).
Rest of wire harness connectors greased.
1861067382_Relayconnectorcontactscleanedandgreased.JPG.186dbfeee37e217a144215ad0b3a96ae.JPG
Wire harness ready to be installed.
Tractor ready for wire harness to be installed.
Edge trim ready to be installed to bottom of front cover.
1593253388_Edgetrimreadytobeinstalledontobottomoffrontplate.JPG.68d23e2397224613d8386ca280b62660.JPG
Wire harness fished under front plate and roughly in position.
195951444_Wireharnessfishedunderfrontplateandroughlyinposition.JPG.eb17970a91f653b8a327140335a1805f.JPG
Fuse block bolted to bracket.
Relay connector bolted to front plate.
Fuse block and relay connector installed.
1681501644_Fuseholderandrelayconnectorinstalled.JPG.ac030e5c6fe0de054b320bcf72006a5b.JPG
Throttle cable clip ready to be installed.
187540207_Throttlecableclipreadytobeinstalled.JPG.545516a07d2463904d0be5622d5c3ebf.JPG
Ground wires and throttle clip bolted down also PTO switch wire connected.
1252264321_GroundwiresandthrottleclipbolteddownalsoPTOswitchwireconnected.JPG.bb79cefc47b18a71021fada96af19a50.JPG
Wire harness routing also showing edge trim installed.
2022614457_Wireharnessroutingalsoshowingedgetriminstalled1.JPG.8d96b3a21ea4587dadda895cabd6a0aa.JPG
1374414726_Wireharnessroutingalsoshowingedgetriminstalled2.JPG.76443e2644be8c87cc44ae875c3fa371.JPG
Wire harness clipped to hoodstand.
Wire harness fastened to battery support.
1509179375_Wireharnessfastenedtobatterysupport.JPG.40df76e04404b386ad5405bb51b386bc.JPG
Wire harness fastened to battery support also taillight wire clipped to hoodstand.
1859488833_Wireharnessfastenedtobatterysupportalsotaillightwireclippedtohoodstand.JPG.24fb12ad2e12b23fd699a51a2418a822.JPG
Taillight wire passed by hydro and fastened to hydro control plate.
Wire harness installed.
Fuses and start relay installed.
Note there are only two fuses because the charge fuse is now to be inline by the starter motor solenoid.
Edited by cleat
  • Like 5
cleat
Indicator board ready for assembly.
Indicator wire harness bolted to bracket.
1826378546_Indicatorwireharnessboltedtobracket.JPG.b9512d099be2221046a7b009f0b56660.JPG
Indicator wire harness socket greased.
This is the whit grease I used.
1009483493_Indicatorwireharnesssocketgreased1.JPG.2b13a2d6d5d78540306ced5abece01a2.JPG
1723691381_Indicatorwireharnesssocketgreased2.JPG.7efadb4dd87716bdfab30237900557cc.JPG
Indicator board assembled.
cleat
Indicator board ready to be installed.
Tractor ready for indicator board to be installed.
1659140553_Tractorreadyforindicatorboardtobeinstalled.JPG.f902b1e3eb86e6708d65080732ea8939.JPG
Indicator board installed.
Indicator board plugged in.
Wire harness will be properly orientated once all connections are made.
cleat
Indicator lens and bushings ready to install.
1763852737_Indicatorlensandbushingsreadytoinstall.JPG.95c5aba1e59294aa413327f02b5a9937.JPG
Indicator bushings installed.
Indicator lens and bushings installed.
cleat
Indicator test switch ready to be installed.
945817735_Indicatortestswitchreadytobeinstalled.JPG.df1d0b61c4ea0a97ef9f328872d20076.JPG
Indicator test switch inner nut installed and tightened.
672173769_Indicatortestswitchinnernutinstalled.JPG.c32b0d89100169e78d45983b6fdb779d.JPG
Indicator test switch back washer installed.
1919656139_Indicatortestswitchbackwasherinstalled.JPG.baf26d574820ad69a7064b82dfc6bdc8.JPG
Indicator test switch installed.
I will plug this in once final wire harness connections are made and the throttle cable is installed.
Indicator board and test switch installed.
432952716_Indicatorboardandtestswitchinstalled.JPG.2a9b338da7bbbedd5539b144b95c95b8.JPG
Edited by cleat
cleat
Hood stand plate ready to assemble.
Headlight switch installed onto hood stand plate.
182629483_Headlightswitchinstalledontohoodstandplate1.JPG.c33672fceea1e8a2f63146bcda5d1fd9.JPG
610689155_Headlightswitchinstalledontohoodstandplate2.JPG.ea70c6d9596e2774e3b25d31c7569e55.JPG
Ignition switch installed onto hood stand plate.
523930924_Ignitionswitchinstalledontohoodstandplate1.JPG.a6c045d45d8a6aa86a8eba8c1540644c.JPG
484483195_Ignitionswitchinstalledontohoodstandplate2.JPG.ce672a4ece12d1a9b8f467b8ece8a27f.JPG
Volt gauge installed onto hood stand plate.
144279188_Voltgaugeinstalledontohoodstandplate1.JPG.6b0b77cbba1790c632f1fc63eaabfea4.JPG
162747898_Voltgaugeinstalledontohoodstandplate2.JPG.62f2d80a23cc1b2ea641bfa3ab88416a.JPG
Hour meter installed onto hood stand plate.
This is the original hour meter from this tractor but I put a piece of black tape over the Toro name (I hope it stays on).
169094809_Hourmeterinstalledontohoodstandplate1.JPG.7e446cb36b79c22d6fa695bc3a066725.JPG
2065126846_Hourmeterinstalledontohoodstandplate2.JPG.492fad1b2d02fcc8e8328226e68b44c3.JPG
Edited by cleat
cleat
Hood stand plate sat aside for now.
Edge trim ready to be installed to top of console.
651162608_Edgetrimreadytobeinstalledtotopofconsole1.JPG.88b5c78b60617820695241578ffa8c32.JPG
822557983_Edgetrimreadytobeinstalledtotopofconsole2.JPG.388847242f9a93c5db7ff69e21bba706.JPG
Edge trim installed to top of console.
cleat
Hood latch ready to install.
Rivets are 1/8" x 0.3" long.
Hood latch top rivet loosely installed IE pulled in most of the way but not all the way using the rivet gun.
1352734521_Hoodlatchtoprivetlooselyinstalled1.JPG.b3f7631a40a2d18f342a20f3d6c70ce1.JPG
1893350951_Hoodlatchtoprivetlooselyinstalled2.JPG.beae7742c30d48faeb0f853e05469f26.JPG
Hood latch lower rivet installed fully then the top rivet fully installed.
This ensures that the latch can be properly aligned and both rivets will easily be installed into the holes.
Same procedure followed for the other side.
  • Excellent 2
cleat
Engine wire harness ready to install.
All push on connectors greased.
Engine ready for wire harness.
Engine wire harness plugged into oil pressure switch and clipped into place.
1595778768_Enginewireharnesspluggedintooilpressureswitchandclippedintoplace1.JPG.aab1ad31545e267e8322101515944e6e.JPG
240807813_Enginewireharnesspluggedintooilpressureswitchandclippedintoplace2.JPG.4c6082c94bbd9cf3628db992550149e3.JPG
Engine wire harness loosely connected to starter motor solenoid.
91275174_Enginewireharnesslooselyconnectedtostartermotorsolenoid1.JPG.c9fbe852e6916f2ce1d92f7081c743ef.JPG
936908844_Enginewireharnesslooselyconnectedtostartermotorsolenoid2.JPG.4e11c90280ce4415797313e40b2ea63c.JPG
cleat
Tapped and blew out intake and exhaust mounting holes.
Screwed a bolt in and measured max thread engagement.
Intake 0.70"
Exhaust 0.60"
Best bolt length for mounting the intake to block that I have on hand is 2" (that gives me about 0.55" of thread engagement).
I will figure exhaust bolt length when I go to install the muffler.
325300922_Tappedandblewoutintakeandexhaustmountingholes1.JPG.185e809125d6137801f574b61334750e.JPG
895009812_Tappedandblewoutintakeandexhaustmountingholes2.JPG.3f3facf21c419c5add32fda0b6712296.JPG
lynnmor
Intake 0.70"
Exhaust 0.60"
I believe that the thread depth varies, I always use a bottom tap to get them as deep as possible.  That cast aluminum strips easily so I want the maximum amount of thread.
cleat
Yep, that is what I did.
cleat
Spare carb I had kicking around from a 416 I bought with a bad engine.
This is the non-emissions carb that I use on all of my Onan engines.
The 416H in this thread is a 1996 so it came with the emissions carb that I am not going to use.
Carb is taken as far apart as I need to (I hope) for cleaning.
WHX??
May not be a big deal but a wear mark on the pulse hose ....
1595778768_Enginewireharnesspluggedintooilpressureswitchandclippedintoplace1.JPG.aab1ad31545e267e8322101515944e6e.jpg
cleat
Well, I can't take a chance on that hose failing or kinking so I replaced it as per WHX??.
New hose may look the wrong length in the picture but it is exactly the same as the original.
1565506313_Fuelpumpvacuumpulsehosenewinstalled.JPG.e621097283062c474326b645a61de4d1.JPG
Edited by cleat
  • Like 4
lynnmor
I always leave that hose a couple of inches too long and then cut it to length at final assembly.  The extra length makes assembly easy and then I can look inside to see how it lays before cutting to length.  The length is very important to keep the hose away from everything.
