lynnmor 8,259 #201 Posted 19 hours ago 3 hours ago, cleat said: Nope, not even close. Looks like you need to jump start your OCD, the 25 fuse is in backwards and there is a debris on the fuse block. 1 Share this post Link to post Share on other sites
cleat 8,078 #202 Posted 19 hours ago 16 minutes ago, lynnmor said: Looks like you need to jump start your OCD, the 25 fuse is in backwards and there is a debris on the fuse block. Ha Ha That will be fixed when the wire harness is officially installed. 😃 1 Share this post Link to post Share on other sites
Handy Don 15,205 #203 Posted 18 hours ago 23 minutes ago, cleat said: That will be fixed when the wire harness is officially installed. 😃 Mighty glad to hear that! Share this post Link to post Share on other sites
cleat 8,078 #204 Posted 3 hours ago Transmission dipstick tube ready to be installed. Transmission dipstick tube liquid Teflon applied. Transmission ready for tube to be installed. Transmission tube screwed in then tightened using a 7/8" crowfoot wrench, extension, and ratchet. Transmission dipstick and silicone grease ready to be applied. Transmission dipstick silicone grease applied to rubber seal. Transmission dipstick installed. 2 Share this post Link to post Share on other sites
