cleat
Got another one. A 416 this time.
cleat
More parts sanded and primed.
1768153392_Frontfenderbracketsandedandprimed.JPG.e3a75adf67c7f6a42438cdffb4eac686.JPG
404688752_Hydrauliccontrolvalvehandlebeadblastedandprimed.JPG.53cb14ab3b2846ec268444a42f4ff876.JPG
cleat
Parts painted.
1341219394_Hydrauliccontrolvalvehandlepainted.JPG.9180b9196e3b38e7123a34e58b90f26b.JPG
cleat
Mid tach plates painted.
Front tach housing painted.
Hydro pulley painted.
Seat lift bracket painted.
Misc hardware, headlight clips, and hydro dipstick painted.
1755196569_Mischardwareheadlightclipsandhydrodipstickpainted.JPG.35181e2db36693abecc7a828137d62c5.JPG
PTO pulley bell painted.
  • Like 4
  • Excellent 2
cleat
Idler pulley one coat of paint.
Lift bar primed.
Rear hitch primed.
cleat
Idler pulley fully painted.
1496060186_Hydroidlerpulleyonecoatofpainted2.JPG.0b16a2dd83998343b15e2d92ff5f6665.JPG
Lift bar painted.
Rear hitch painted.
cleat
Front wheels with tires just removed.
Front wheels wire brushed, sanded and put on a rod for painting.
Front wheels primed.
  • Like 5
cleat
Front wheels have first coat of silver paint applied.
After paint dries for a while I will loosely mount the tires and complete the painting.
1726852788_Frontwheelsfirstcoatofpaintcomplete1.JPG.692c82b72c63ccc0d21b0b3548c3141b.JPG
1036573346_Frontwheelsfirstcoatofpaintcomplete2.JPG.c4bacefb7ea37053cd1d8b808b920524.JPG
159560503_Frontwheelsfirstcoatofpaintcomplete3.JPG.e412d071698412852c95a10e55970bfe.JPG
  • Like 7
cleat
Rear fender was bent by the PO to fit oversize tires.
Fender straightened to the best of my ability (I am no body man).
1972196110_Rearfenderstraightenedanddecalremoved.JPG.17f2802d248b500fddfb9f8c8fab380b.JPG
  • Like 6
cleat
New seal installed into PTO pulley.
New thrust bearing and stub shaft installed into PTO pulley.
871900010_PTOpulleynewthrustbearingandstubshaftinstalled.JPG.c9153b7c9fde023ba40d4de2d5c16fa0.JPG
cleat
Installed tires onto front wheels.
Valve stem hole is taped off as it will get installed after wheels have the final coat of paint and clear applied.
Started sanding fender.
ebinmaine
19 minutes ago, cleat said:
fender
How are you finding the sheet metal to be overall? Looks pretty straight.
cleat
Rust and paint wise, the best I have ever bought.
The rear fender was bent out to fit the oversize ATV tires the PO had fitted.
I straightened it the best I could and it now looks good.
cleat
I used a little spot putty on the small remaining dimples on the rear fender.
Block sanded until as flat as I could get it.
cleat
Bottom of rear fender painted.
One coat of clear applied.
Bottom will just get one coat.
  • Excellent 3
Brockport Bill
very impressive !!!!!!
do you do all bloc hand sanding? or do you use any power sanders or grinder sanding discs etc? When convenient, could you post a photo or tell us the light redish primer paint product you use? thanks
