Surrey,UK based 244/5 4 #1 Posted November 29, 2024 Model 72060 3900105 : the cutting deck has rusted away, non-repairable alas, so I'm looking for replacement if anyone is dismantling . Thanks for help. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,508 #2 Posted November 29, 2024 Two blade deck or 3-blades? 78215 38" Side Discharge Mower 78216 38" Side Discharge Mower Can be equipped with Recycler Kit 79170 78230 42" Side Discharge Mower Share this post Link to post Share on other sites
Surrey,UK based 244/5 4 #3 Posted November 29, 2024 Thanks for post. It's a 2 blade ,side discharge with 3 rubber balls for motion support Share this post Link to post Share on other sites
wh500special 2,465 #4 Posted November 29, 2024 I’m not 100% positive about this, but I am fairly sure the decks from the 260 series (successor to the 240) will fit. That might open some options for you. of course a friend with welding equipment opens virtually unlimited options as well… Steve 1 Share this post Link to post Share on other sites
Surrey,UK based 244/5 4 #5 Posted November 29, 2024 32 minutes ago, wh500special said: I’m not 100% positive about this, but I am fairly sure the decks from the 260 series (successor to the 240) will fit. That might open some options for you. of course a friend with welding equipment opens virtually unlimited options as well… Steve Thank you for the advice, I'll seek out local welders to see if a replacement is possible to make. Share this post Link to post Share on other sites
Surrey,UK based 244/5 4 #6 Posted February 27, 2025 (edited) On 11/29/2024 at 4:13 PM, wh500special said: I’m not 100% positive about this, but I am fairly sure the decks from the 260 series (successor to the 240) will fit. That might open some options for you. of course a friend with welding equipment opens virtually unlimited options as well… Steve Edited February 27, 2025 by Surrey,UK based 244/5 Duplication Share this post Link to post Share on other sites
