peter lena 9,235 #1 Posted November 19, 2024 https://www.zoro.com/campbell-chain-fittings-316-x-1-repair-link-steel-zinc-plated-upc-tagged-t5950124/i/G3562067/?utm_source=google&utm_medium=surfaces&utm_campaign=shopping feed&utm_content=free google shopping cl handy for any chain set up or spring addition , add a spring to a lever point , for easier lift start , if you don't have a hydro , your left arm will thank you . pete 1 Share this post Link to post Share on other sites
peter lena 9,235 #2 Posted November 19, 2024 @Bar Nuthin long ago replaced the 2 lower corner , / hood frame bolts with 3/8 threaded eye bolts . good spot for a spring assist pull point , probably removed , two thirds of plow lift lever effort , just holds it off ground . experimented with various springs , moved the eye bolts , to their easiest , spring pull assist point , regularly experiment with an issue , make it go away . pete 1 Share this post Link to post Share on other sites
Bar Nuthin 1,015 #3 Posted November 20, 2024 2 hours ago, peter lena said: @Bar Nuthin long ago replaced the 2 lower corner , / hood frame bolts with 3/8 threaded eye bolts . good spot for a spring assist pull point , probably removed , two thirds of plow lift lever effort , just holds it off ground . experimented with various springs , moved the eye bolts , to their easiest , spring pull assist point , regularly experiment with an issue , make it go away . pete I used the squeeze chain link to connect my deck chain to the eye bolt. Most recently I modified a standard snow thrower flag to be spring assist. Heavy springs have purpose! I like the idea of eye-bolts in the front for spring assist on a plow. I need to fabricate a solid down-pressure link first - for stubborn spots. 1 Share this post Link to post Share on other sites
peter lena 9,235 #4 Posted November 20, 2024 @Bar Nuthin like the fact that you are , looking and thinking about the issue , that spring was about 6' long with tapered ends , was looking for any related pictures , for you , can,t find exact name . thing I really like about it is , lift lever effort , is much easier , holds it just off ground . also going to connect those hood mount eye bolts , so there is an equal pull , from both sides of frame front . commonality to W/H attachments , is their amazing functional ease , with simple , connection / lubrication detailing , washers lube , etc . garage door multi hole lift bar , is terrific , for a bolt in down pressure , cut out what ever you need , paint it black / red . be looking for related for you , glad you are on it , pete 1 Share this post Link to post Share on other sites
peter lena 9,235 #5 Posted November 20, 2024 @Bar Nuthinhttps://www.lowes.com/pd/Hillman-5-1-2-in-Zinc-Gate-Extension-Spring/3115905?user=shopping&feed=yes&srsltid=AfmBOoodfh0e2iorOAd9CYk9PlUqUOe-eVhBHX-fm1cRc7ljAJ_fjkIygjA this is the type of tapered end spring used , if yo have a selection , about 6" long , bent hook ends , holds a plow off ground , pete 1 Share this post Link to post Share on other sites
