mike avad 60 #1 Posted October 16, 2024 I have a 1971 wheel horse raider 12 is there a bracket that go's under the seat on this or dose it just sit flat on the fender pan? Iv look high and low for photos and info Share this post Link to post Share on other sites
953 nut 67,243 #2 Posted October 16, 2024 Seat bolts directly to the pan but you can jack it up a bit if you are long legged. 3 Share this post Link to post Share on other sites
ebinmaine 79,521 #3 Posted October 16, 2024 There are seat "springs" on my 1971 Bronco 14 Share this post Link to post Share on other sites
mike avad 60 #4 Posted October 17, 2024 thanks for the reply's Share this post Link to post Share on other sites
peter lena 9,934 #5 Posted October 17, 2024 @mike avad was just snoopin around , for your seat info , found this picture fest , gives a lot of insight , those seats / base mount are can easily be tweaked to fit your situation , unless you have to have exact pristine factory fit , done a lot of seat refitting ,not difficult , pete 1 Share this post Link to post Share on other sites
kpinnc 18,723 #6 Posted October 17, 2024 18 hours ago, ebinmaine said: There are seat "springs" on my 1971 Bronco 14 I added them to mine as well. Depending on the terrain you use your tractor on, as well as the amount of seat time you will have, a set of springs most definitely reduce what pop called “planter fatassyitis”, which I acquired from using no springs… 1 2 Share this post Link to post Share on other sites
mike avad 60 #7 Posted October 18, 2024 YES I like that I look for a set thanks alot Share this post Link to post Share on other sites
Maz91 305 #8 Posted October 18, 2024 On 10/16/2024 at 7:12 PM, mike avad said: I have a 1971 wheel horse raider 12 is there a bracket that go's under the seat on this or dose it just sit flat on the fender pan? Iv look high and low for photos and info My ‘71 raider 12 had no springs. (Just for the record) 1 Share this post Link to post Share on other sites
Lee1977 7,690 #9 Posted October 18, 2024 5 hours ago, Maz91 said: My ‘71 raider 12 had no springs. (Just for the record) I'm a blind welder is the reason I didn't add this picture to the build. Got old and can't see. I add the 1/8" x 2" flat to the front and a 2"x2" x 1/8" angle to the rear. Also added some 1" square tube on top of the fender with a few washers to raise the front of the seat. The fender also hinges off a 3/4" rod welded in the seat frame. where is also a fender latch at the front . 1 Share this post Link to post Share on other sites
