Raider12
Tiller Idler Pully's Which ones do I need
Raider12
I have a 36" tiller and I think I do have the idler pulley that mounts in the Attach-amatic for the belt. But my question is, do I need both of the pieces you see in the photo? I do not have the larger part that looks like it mounts the rear axle. Can anyone give me some info on this?
Michael Bullington
yes you need both...i have the same setup and the other section your missing mounts in the back of the frame holes down in front of the trans...the other piece in your picture mounts on the rear axles
Raider12
To make this tiller work appears to be a pain in butt! Maybe more trouble than it's worth? Anyone have the part I missing? Or maybe the parts needed a based on the model of tractor your using it on? I want to put this on my Raider 12 or my 520? :scratchead:
sawhorse
"4starcstms" posted a series of good pictures of a tiller install on this site somewhere.
It helped me out a lot.
Michael Bullington
Ive never used this attachment, but from what i understand it wasnt that great ...I would think there is a much improved verison out there for the 520....if you decide to sell that set you have I would like to have it...these parts are difficult to track down.., :scratchead:
Raider12
I use a tiller on my 520. I do not use or have the top thing that you have pictured. I only use the pulleys that you have pictured at the bottom.
This is what I was thinking, I looked up the parts on the Toro parts site and I didn't see anything like the part on the top either. This must be for a different model of tractor and tiller. Maybe a GT 14 or a D series? But the link you provided with the pics says it all. Thanks for the reply's! :scratchead:
Can any one tell me what the belt size is for this set up? If I use it on my Raider 12 will the belt be different for the 520? :hide:
Michael Bullington
okay that part goes with TILLER MODEL RT367 (you can get the manual at the yahoo groups)
it is designed to fit all 6 speed tractors and wheel o matics.
It is not for a different model tractor is goes with the Raider 12, not a gt14 or D series..I dont know where that information came from????? where did you get that???
The link to the pics is a total different Tiller setup :scratchead:
Im missing the belt cover that goes with it
Raider12
I was just guessing about a different model of tractor. It appears the difference is in the model of tiller. You all have been a bunch of help.
:scratchead:
