ebinmaine 80,614 #26 Posted April 20, 2025 2 minutes ago, fourwheelhorseman said: I got it and it works perfect! It’s a pretty streightfoward hookup. I’m getting ready to use it in a couple of days Niiiiice Share this post Link to post Share on other sites
ineedanother 2,861 #27 Posted April 21, 2025 2 hours ago, fourwheelhorseman said: I got it and it works perfect! It’s a pretty streightfoward hookup. I’m getting ready to use it in a couple of days Good deal. You'll learn pretty quickly to appreciate the height adjustment on your manual lift, especially if you're breading new ground. Start relatively shallow and go deeper on each pass and you'll figure out how aggressive you can be. Throwing the tiller drive belt is to be expected until you get everything dialed in. Share this post Link to post Share on other sites
fourwheelhorseman 362 #28 Posted April 23, 2025 On 4/20/2025 at 8:07 PM, ineedanother said: Good deal. You'll learn pretty quickly to appreciate the height adjustment on your manual lift, especially if you're breading new ground. Start relatively shallow and go deeper on each pass and you'll figure out how aggressive you can be. Throwing the tiller drive belt is to be expected until you get everything dialed in. I used it last year a lot, the first time I did indeed throw the tiller belt, however I think it was due to arouting issue. I pulled the tiller off the tractor to install my snowcab/snowblower for last winter, now I’ve reinstalled it. I plan on using it today.. actually looking forward to it! 2 1 Share this post Link to post Share on other sites
