hotajax 281 #1 Posted September 13, 2024 On my OEM wheels, a straight zerk is threaded into the hub. Just curious - how is the drill and tap held at a 45-degree angle during the drill and tap process? Share this post Link to post Share on other sites
Ed Kennell 46,798 #2 Posted September 13, 2024 The hubs are probably drilled and tapped by a lathe attachment while they are being bored and parted off from bar stock in an automatic lathe. Share this post Link to post Share on other sites
stevasaurus 23,784 #3 Posted September 13, 2024 You can buy grease zerks that go in straight and have a head that is 45 degrees. 2 Share this post Link to post Share on other sites
hotajax 281 #4 Posted September 13, 2024 Yeah, I know about the 45-degree and 68--degree elbows. But I wanted to know how to hold that angle while drilling and tapping. 1 Share this post Link to post Share on other sites
Chaz54 102 #5 Posted September 13, 2024 Do you have a picture of what you are referring to? Share this post Link to post Share on other sites
wallfish 20,386 #6 Posted September 13, 2024 1 hour ago, hotajax said: Yeah, I know about the 45-degree and 68--degree elbows. But I wanted to know how to hold that angle while drilling and tapping. Why would you want to drill and tap them on a 45 deg angle? It probably wouldn't work for a grease zerk anyway since the threads on them aren't very long. Plus it could easily get knocked off too 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,418 #7 Posted September 13, 2024 Could you weld a nut over the hole and use an angled fitting? Share this post Link to post Share on other sites
WHX?? 57,645 #8 Posted September 13, 2024 I know what He's talkin about. I think he's tryin to put them in rims that don't have zerks. Had to re-tap many and yes you can't get a tap wrench or drill in there. I just use a small wrench and a 1/4 turn or so is all you get so slow but works. Learned not to take them out unless absolutely necessary. If you are using rims that don't' have them just use sealed bearings. Many of use have just gone to not greasing. Re-grease per greasy pete tho. 1/4-28 is the tap size. 1 hour ago, wallfish said: the threads on them aren't very long. They are available in long thread. Share this post Link to post Share on other sites
ri702bill 12,699 #9 Posted September 13, 2024 4 hours ago, stevasaurus said: You can buy grease zerks that go in straight and have a head that is 45 degrees. Share this post Link to post Share on other sites
953 nut 68,179 #10 Posted September 13, 2024 If you have a drill press I would suggest you start a pilot hole at ninety degrees to center the bit then clamp the wheel to your drill's bed, tilt it to forty-five degrees and drill into the pilot hole. Share this post Link to post Share on other sites
wallfish 20,386 #11 Posted September 14, 2024 2 hours ago, WHX?? said: If you are using rims that don't' have them just use sealed bearings. Absolutely !!! This is the solution even with grease zerks in place. 2 hours ago, WHX?? said: They are available in long thread. Do you still think you would want that thing on an angle into a 45 deg hole? Plus that rim metal is thin Share this post Link to post Share on other sites
hotajax 281 #12 Posted September 14, 2024 9 hours ago, wallfish said: Why would you want to drill and tap them on a 45 deg angle? It probably wouldn't work for a grease zerk anyway since the threads on them aren't very long. Plus it could easily get knocked off too That's the way the OEM wheel was configured. I thot about putting in a 45, but i can't get the clearance to drill and tap on that small wheel. Not much room to work. I can't even get in there with a grease gun on a straight zerk. Thanks Share this post Link to post Share on other sites
peter lena 9,993 #13 Posted September 14, 2024 @hotajax as referred , a picture would be nice , however , never let a " sealed " bearing stop me from correcting the issue , WRONG LUBRICANT . having done over all my wheels , and also proper wheel shimming , to eliminate side play shucking . the combo of side wheel play , and ceiling fan lube , does not make for a reliable set up . personally only buy , bearings with a wide rubber side grease shield , easy to remove , clean out , repack with lucas polyurea , 550 deg , grease . my entire PTO DRIVEN , set up is detailed like that . imagine no belt / clutch screaming , just smooth easy movement . wheels are easy , pete Share this post Link to post Share on other sites
moe1965 774 #14 Posted September 14, 2024 If held in place at a 45 degree angle in a vice use a center drill to start your hole then you can drill with the correct drill for a tap. Can be done on a bridge port. Drill and power tap. A machine shop should be able to help you out. Share this post Link to post Share on other sites
wallfish 20,386 #15 Posted September 14, 2024 10 hours ago, hotajax said: That's the way the OEM wheel was configured. I thot about putting in a 45, but i can't get the clearance to drill and tap on that small wheel. Not much room to work. I can't even get in there with a grease gun on a straight zerk. Thanks Why isn't just using sealed bearings an option? No greasing and no zerks. All of that extra grease in there does is make a big mess if the wheel ever needs to be removed. Yes it's simple to give the bearings a quick squirt with zerks in place but then again you don't need to do anything with sealed bearings. Share this post Link to post Share on other sites
953 nut 68,179 #16 Posted September 14, 2024 Are we talking about a front wheel for the Wheel Horse or one of those little mower wheels? Share this post Link to post Share on other sites
hotajax 281 #17 Posted September 15, 2024 Talkin about the 15" front tractor wheels, not the ones for the deck. Share this post Link to post Share on other sites
hotajax 281 #18 Posted September 15, 2024 So if I understand the people who are in favor of sealed bearings, clean out your bearings, apply premium grease, and reinstall the shields and forget about lubing the spindle? Share this post Link to post Share on other sites
wallfish 20,386 #19 Posted September 15, 2024 1 minute ago, hotajax said: So if I understand the people who are in favor of sealed bearings, clean out your bearings, apply premium grease, and reinstall the shields and forget about lubing the spindle? Yup, that's it. The grease in the center of the bearings is just a waste of grease that is there to push grease into an unsealed bearing. It does absolutely nothing to lube the spindle since nothing is even touching the spindle in that area. The only place that needs grease is inside of the bearings. The seal on the bearing also keeps dirt out 2 Share this post Link to post Share on other sites
Wild Bill 633 937 #20 Posted September 16, 2024 Bearing Buddy's come in 1.781, 1.810, 1.938, 1.968, 1.980 diameters. I use them on all of my Simplicities. Share this post Link to post Share on other sites
hotajax 281 #21 Posted September 16, 2024 3 hours ago, Wild Bill 633 said: Bearing Buddy's come in 1.781, 1.810, 1.938, 1.968, 1.980 diameters. I use them on all of my Simplicities. Bearing Buddy: Pull off the seals on the bearings? Share this post Link to post Share on other sites
hotajax 281 #22 Posted September 16, 2024 (edited) I installed new ball bearings, all the way around. Shimmed up the axle so there is almost no perceptible end play. The spindle doesn't seem to have any wear rings, yet the one wheel still wobbles, even with the tractor going straight. Could this be wear inside the hub where the bearing is placed? Thanks. 314-8 front wheels. Edited September 16, 2024 by hotajax Share this post Link to post Share on other sites
wallfish 20,386 #23 Posted September 16, 2024 That kind of wear or fit you could simply feel by jacking it up and trying to wiggle the wheel. Maybe a bent rim. While it's jacked up give it a good hard spin and watch it 1 Share this post Link to post Share on other sites
Ed Kennell 46,798 #24 Posted September 16, 2024 7 hours ago, Wild Bill 633 said: I use them on all of my Simplicities. I use BBs on all my boat trailers that I constantly dunk in salt water. The pressurized hub does keep the water out. I never felt a need on a tractor though. Sealed bearings work fine on all my tractors. I do store them inside. 2 Share this post Link to post Share on other sites
