Ed Kennell 45,055 #1 Posted September 12, 2024 Found this interesting deck at the auction today. I also picked up this for 2 bucks. 2 3 1 Share this post Link to post Share on other sites
Brockport Bill 2,234 #2 Posted September 12, 2024 wondering if that 42 deck is on front or back? -- if its on front that must be weird pushing it with rear of deck hitting grass blades "backwards" ? Share this post Link to post Share on other sites
Ed Kennell 45,055 #3 Posted September 12, 2024 6 minutes ago, Brockport Bill said: wondering if that 42 deck is on front or back? -- if its on front that must be weird pushing it with rear of deck hitting grass blades "backwards" ? It is set up to be towed. You can see the tow bar in the second pic. It actually looks like it is well made with a 12HP electric start Briggs. 2 Share this post Link to post Share on other sites
Handy Don 16,025 #4 Posted September 12, 2024 12 minutes ago, Ed Kennell said: It is set up to be towed. You can see the tow bar in the second pic. It actually looks like it is well made with a 12HP electric start Briggs. Except that it appears to lack height adjustment, it looks like a light duty brush-hog. What did it go for? Share this post Link to post Share on other sites
Moparfanforever 925 #5 Posted September 12, 2024 That deck looks like a good idea!! Hope it works well!! Share this post Link to post Share on other sites
Ed Kennell 45,055 #6 Posted September 12, 2024 31 minutes ago, Handy Don said: Except that it appears to lack height adjustment, it looks like a light duty brush-hog. What did it go for? Yep, the height is fixed. I would have used longer angle and mounted the fronts on the same angle as the rears. It would have been a simpler and stronger design. Sold for $25. A cheap running 12Horse electric start Briggs. Share this post Link to post Share on other sites
Handy Don 16,025 #7 Posted September 12, 2024 22 minutes ago, Ed Kennell said: Yep, the height is fixed. I would have used longer angle and mounted the fronts on the same angle as the rears. It would have been a simpler and stronger design. Good point. Relying on the deck shell for structure is less than ideal. $25 for a running electric start engine isn’t bad. Share this post Link to post Share on other sites
