jdog_kustoms
d series loader
jdog_kustoms
does anyone have the specs and pics of a loader for a d 180 i would like to built one for my tractor and what to make it close to factory and if you have a factory and have any issues let me know cuase i will upgrade as i built
or if someone is near gettysburg pa that i could come see the loader take pics and measurments
thanks
for all the help
defed
i just got a 07-72FL01 loader, which technically fits a D-250. i'm trying to find the measurements of the loader meant for the D-auto's to see if it is basically the same loader, or if it's physically larger. i suspect the different model number covered the tractor mount and pump coupling, and the rest is the same.
if i find it to be, i could send some dimensions and pics.
Dave
d180man
Hi i will look in our book to see if i have some info like that ? our load is on the tractor right now but we may be taking it off to work on it and paint it? if we do we are going to make a wood copy of it so we can make more of them if we wount! but the d250 load is bigger as for as i know it is not made the same but they look all most the same! do you have 1" axles on your 180? i will try to list some photos i have got of the loader! good luck! :scratchead: :hide:
d180man
Hi here is some photos! for tractor we have looked at ! they may help!
this is how they go on a d160 d180 and d200 and how the pump goes on ! it is belt drive!
This is a d160 d180 and d200 under frame if you look et the d250 they are not the same!
250 photos and look at the under frame!
Here is how a d250 pump goes on!
i have some more photos you can look at them here ! hope they help if you have more ? just ask!
http://s285.photobucket.com/albums/ll56/ar...orse%20loaders/
