cumminscook 60 #1 Posted September 8, 2024 hey guys im looking for a starter key switch for my GT-14 let me know if or where i can get one thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,416 #2 Posted September 8, 2024 What type of ignition do you have - battery powered or breakerless magneto. How many key positions? Have a tractor model number? Share this post Link to post Share on other sites
8ntruck 9,175 #3 Posted September 8, 2024 Gt 14's came with Kohler K321 engine. It is probably a coil/points system - if the engine is still original. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,416 #4 Posted September 8, 2024 31 minutes ago, 8ntruck said: Gt 14's came with Kohler K321 engine. It is probably a coil/points system - if the engine is still original. A Wheel Horse GT-14 is the only information he has offered. That is like asking for a set of spark plugs for a Ford passenger car. If we don't get it right this fellow is in more trouble. There are 9 different GT-14 models and I don't feel like digging up all those wiring diagrams to see what model uses what ignition switch. 3 1 Share this post Link to post Share on other sites
SylvanLakeWH 31,997 #5 Posted September 8, 2024 This thread should be moved to Wheel Horse Electrical or Wheel Horse General section. This area is for electric tractors only. Will get more replies elsewhere... Share this post Link to post Share on other sites
953 nut 68,150 #6 Posted September 8, 2024 (edited) @cumminscook, as Garry said we need a bit more information to provide a correct answer. The model number tag is on the right hand side of the dash tower, we need to know that number to know what electrical system you have. First, are you sure you need a new ignition switch? What is or isn't happening that leads you to think a new switch is needed? What trouble-shooting have you done? Looking at the hood decals on your GT-14 it may be a 1970, here is a link to information on it. https://www.wheelhorseforum.com/search/?&q=GT-14 1970&type=downloads_file&nodes=8&search_and_or=or&sortby=relevancy Edited September 9, 2024 by 953 nut Share this post Link to post Share on other sites
cumminscook 60 #7 Posted September 9, 2024 sorry guys for putting this in this topic i think i found the switch i need 103-990 yes its a points and coil system 1 Share this post Link to post Share on other sites
cumminscook 60 #8 Posted September 9, 2024 GT 14 #10502 7 serial # 855864 engine 14 hp Kohler model # K321S spec # 60149a serial # 3245880 so this is all the numbers i have if this helps guys thanks im not good with computers sorry! Share this post Link to post Share on other sites
cumminscook 60 #9 Posted September 9, 2024 20 hours ago, gwest_ca said: A Wheel Horse GT-14 is the only information he has offered. That is like asking for a set of spark plugs for a Ford passenger car. If we don't get it right this fellow is in more trouble. There are 9 different GT-14 models and I don't feel like digging up all those wiring diagrams to see what model uses what ignition switch. i understand sorry Share this post Link to post Share on other sites
cumminscook 60 #10 Posted September 9, 2024 5 minutes ago, cumminscook said: GT 14 #10502 7 serial # 855864 engine 14 hp Kohler model # K321S spec # 60149a serial # 3245880 so this is all the numbers i have if this helps guys thanks im not good with computers sorry! do you guys think the switch 103-990 is right? Share this post Link to post Share on other sites
cumminscook 60 #11 Posted September 9, 2024 16 minutes ago, cumminscook said: i understand sorry sorry i did not know there was 9 models of the GT14 Share this post Link to post Share on other sites
953 nut 68,150 #12 Posted September 9, 2024 6 minutes ago, cumminscook said: GT 14 #10502 That would be a 1972, totally different ignition wiring from the 1970 so please don't use that diagram. Presuming the wiring on your tractor has not been altered it should be like the 1972 Bronco with battery ignition. You will need to do a bit of rewiring to use the 1043-990 but it will get the job done for you and the 101917 switch may not be available any more. You will no longer have the ignition only position where the PTO can't be turned on but that was an unnecessary position in my opinion. The basic drawing below the attachment may help you, it uses the 103-990. Share this post Link to post Share on other sites
cumminscook 60 #13 Posted September 9, 2024 this will help thanks this tractor is all stock i will try to send you pics 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,416 #14 Posted September 9, 2024 If you want to make the ignition switch wiring neat there is a 5-wire connector available to do so. Click on the picture to see it. Share this post Link to post Share on other sites
