Dgilmored 7 #1 Posted September 7, 2024 I recently acquired a c165, model 16k801. Its in very good condition accept for the wiring. I installed a new battery but no crank with the key. i crossed the terminals at the solenoid which cranked the engine with no start. There is no spark at the points. At this point I want to sort out the wiring. I found a wire diagram for a 1981 c165 which should get me going. My issue is the rectifier. The wires coming from the engine are going to a small square box with only two wires. One is a #10, the other a #18. Is this the rectifier? My diagram shows a three wire terminal. photos.google.com: 2.webloc Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,489 #2 Posted September 7, 2024 There was a 2-wire regulator used. Look close and one of the AC wires from the stator is connected to the DC+ regulator output. The 3-wire regulators are the same but we don't see it. It is connected inside the regulator. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,489 #3 Posted September 7, 2024 Suspect your full tractor model number is 11-16K801 making it a 1984 model. Share this post Link to post Share on other sites
Dgilmored 7 #4 Posted September 7, 2024 Thats correct. Thank you for the info. Is that part still available if needed? Share this post Link to post Share on other sites
953 nut 69,479 #5 Posted September 7, 2024 2 hours ago, Dgilmored said: I installed a new battery but no crank with the key. i crossed the terminals at the solenoid which cranked the engine with no start. There is no spark at the points. At this point I want to sort out the wiring. The problem could be a loose or corroded electrical connection. Clean and tighten ALL electrical connections including grounds. Amp meters sometimes cause this type of problem, connect both of the wires going to the amp meter to one another (bypassing the meter). Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,489 #6 Posted September 7, 2024 Yes it is but Toro is very proud of it. https://www.partstree.com/parts/toro-commercial-109313 I would go for a more popular 3-wire version with the large aluminum heat sink if you have somewhere to mount it. Share this post Link to post Share on other sites
Dgilmored 7 #7 Posted September 7, 2024 There was a real spaghetti mess of wire. I'm going to get it back to basics, by passing all the safety switches and asseories for now just to get it running. I have plenty of room for the 3 wire version. Amazon is not as proud as Toro. Thank you for all your help. Share this post Link to post Share on other sites
953 nut 69,479 #8 Posted September 7, 2024 5 hours ago, Dgilmored said: plenty of room for the 3 wire version. Not all three wire voltage regulators are created equally. You need the larger voltage regulator with a bid heatsink unless you will be mounting it in the fan shroud where it will have a cooling flow. Share this post Link to post Share on other sites
