Dawgman 5 #1 Posted September 6, 2024 I have a 2004 Toro 315-8. The rear wheels are not original. The tires that are mounted are 23x10.5x12. I want to go back original with 23x9.5x12 tires. What size wheel do I need to use for the tires? Thanks. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,237 #2 Posted September 6, 2024 What is the width of the wheel you have? Wheel width is about 1/2" less than the overall width. You measure inside the two lips at the tire beads. Of course it would be easier with the tire removed from the rim but you can stick a rule through the wheel and figure it out. 2 Share this post Link to post Share on other sites
pfrederi 20,562 #3 Posted September 6, 2024 There is probably more size variation between brands than there is between a 10.50 and a 9.50. A Carlisle 9.50 will probably be wider than a Deestone 10.50 for example. 2 Share this post Link to post Share on other sites
rick 296 #4 Posted September 7, 2024 Carlisle specs a 7" rim for a 12x9.50-12 tire. 1 Share this post Link to post Share on other sites
clueless 3,403 #5 Posted September 7, 2024 They will fit the wheel just fine, they are probably the original wheels. Share this post Link to post Share on other sites
Lee1977 7,637 #6 Posted September 8, 2024 (edited) I have 24 x 9.50 x 12 on my 1989 520 with 7" wide wheels. Edited September 8, 2024 by Lee1977 2 Share this post Link to post Share on other sites
