Countdown To Christmas!
truckin88
Ag Tire question 312-8
truckin88
My 312-8 has what looks to be the original Armostrong 22x9-12 turfs on armostrong 12x7 rims. Can I run 23x8.50-12 ags? on the rear.
hodge
I have a 310-8 and I put 23-10.50-12's on, (ags) and they fit nicely, and pull great. What I don't know is if the narrower size will work or not on those rims.
canam1991
yes you can that what i have on mine
truckin88
The problem with 10.50's is you can only run large decks, not really the small ones, as the back wheel hits the rear deck wheels. I had them on the 520 in my avatar with a 48" deck, they worked well. The 312 is using a 37 w/ bagger. I was figuring 8.50 would work well, as I have those on the 120.
dgjks6
i put 23x10.5x12's on my 312. Have not tried the 37 inch deck, but I tried a 42 inch side discharge and the gauge wheels hit the tires. Then I tired a 36inch rear discharge which worked fine.
truckin88
this is what I thought would happen and with the 8.50's you would not have this issue, thanks for sharing. I love the 10.50 look, but don't want the clerance issues. on my 520 is looked mean, but the 8.50's look cool on my C-120
Wheel Horse Fan
You also have to remember that different brands are different widths (from what I have seen) I have deestone 10.5s but there not really much wider then some 8.50s.
buckrancher
I have the 23x10.5x12 ag's on my 314-8 with a 42" rear discharge and there's
plenty of clearance
