RustyGold 88 #1 Posted August 18, 2024 Scored a 1985 312-8 today for only $450. It’s 1 owner & only has 600 hours !! This will be my backup machine to my 315-8 . What a nice machine!! 8 7 Share this post Link to post Share on other sites
Sparky-(Admin) 26,898 #2 Posted August 18, 2024 With steel weights and a deck .. nice score 5 Share this post Link to post Share on other sites
ebinmaine 81,282 #3 Posted August 19, 2024 9 hours ago, Sparky said: With steel weights and a deck .. nice score Looks like @RustyGold bought the weights and deck and got a free tractor! Well done! 4 Share this post Link to post Share on other sites
peter lena 10,125 #4 Posted August 19, 2024 @RustyGold nice pick up ! would take advantage of what works and enhance / verify that area , would also get a penetrating oil soak down going on that paint , when wiped out dry should look perfect era patina , would also get that trans oil dropped , flushed out , like hi mileage ATF fluid , for crud cutting action and drive around ability , get some miles and time on that oil , use every gear / range , regularly check its condition for effect , new shift boot , greased on the bottom INSIDE , so it easily slides over the irregularities on top of trans , add a TYE WRAP ABOVE THE BOOT , so it stays in place , like a CLIMBING GEAR OIL , for better spraying / fling , regularly check my trans , always full / clean , good luck with it , pete 1 1 Share this post Link to post Share on other sites
