Sparky-(Admin) 26,898 #1 Posted August 18, 2024 My 42” RD could use new blades…are the Gator blades all they’re cracked up to be? The TORO number for the 3 blade kit is 106635. The Gator blade website doesn’t cross reference numbers, anyone use them and can share the Gator number? Share this post Link to post Share on other sites
ebinmaine 81,282 #2 Posted August 18, 2024 Following. I have the same deck. Share this post Link to post Share on other sites
Sparky-(Admin) 26,898 #3 Posted August 18, 2024 1 minute ago, ebinmaine said: Following. I have the same deck. Stalker! 4 Share this post Link to post Share on other sites
ri702bill 13,394 #4 Posted August 18, 2024 Related item - I like to use the Gator style blade on a walk behind trimming mower. It is a high lift blade that has the additional "chopper" teeth to recut DRY glass clippings. About euqally as bad as any other blade when cutting wet grass....... 1 Share this post Link to post Share on other sites
Skwerl58 843 #5 Posted August 18, 2024 I have Gators on a couple of my mowers and they are good blades. High lift and are usually made heavier and they hold up well. Sorry I can't help with the paart number. 1 Share this post Link to post Share on other sites
TractorEd 675 #6 Posted August 18, 2024 43 minutes ago, ebinmaine said: Following. I have the same deck. But you don’t cut grass with it 😂 2 Share this post Link to post Share on other sites
clueless 3,440 #7 Posted August 18, 2024 If your just looking to replace your blades with something a bit cheaper than the OEM set just buy some aftermarket standard lift ones. RD deck don't really cut any better with high lift blades including Gator blades. 1 1 Share this post Link to post Share on other sites
ebinmaine 81,282 #8 Posted August 18, 2024 17 minutes ago, TractorEd said: But you don’t cut grass with it 😂 Not yet. But we are working on one that will be used out in the area surrounding the garden. 1 Share this post Link to post Share on other sites
TractorEd 675 #9 Posted August 18, 2024 I have Gator blades for 3 different tractors now. 1 is a 10hp Wheel Horse with a 37” deck. I think the blades work just as good as the standard ones. And a little better in some ways. The lift is noticeably more and it chops the grass up a little more, but not as much as the other 2 non WH 54” & 60” 25hp+ tractors. So, I say it’s an improvement just don’t expect a whole lot from a shallower WH deck. Your 42” may be even better. 1 1 Share this post Link to post Share on other sites
TractorEd 675 #10 Posted August 18, 2024 (edited) I’m refurbishing a 48” WH 78631 deck at the moment and I do plan on putting Gator blades on it. After that, I have a 42” deck to restore and I plan to do the same with it; so it would be interesting to see how it works out for you if you decide to try it. Oh, and as for which Gator blades to get, I just find the ones of the same length. Sometimes you can find a set of three, sometimes individually; and sometimes a pair which isn’t ideal, but maybe a pair and a single. As long as they’re the right length you should be good. G1 is standard, G3 is better and G5 is best/toughest/thickest. But G3’s are certainly tough enough (G1’s probably are too, I just don’t own any of those). Edited August 18, 2024 by TractorEd 1 1 Share this post Link to post Share on other sites
cod 137 #11 Posted August 18, 2024 I've got 2 42" RD's, one with a recycler baffle and the other is completely naked. I've been using Gator G3 90 Blades from Jack's Small Engines, Part# 90-643 and I think they are great for my needs. I run 6 blades (3 Gators and 3 non Gators)under the recycler specifically for mulching leaves in the Fall. The grass deck only has Gators. Good luck! 1 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,557 #12 Posted August 18, 2024 90-643 no longer available and have never found any other Gator blade we can use. Share this post Link to post Share on other sites
Sparky-(Admin) 26,898 #13 Posted August 18, 2024 18 minutes ago, gwest_ca said: 90-643 no longer available and have never found any other Gator blade we can use. Great! Was just about to start looking em up. I’ll do the measurements and hole size I guess. 1 Share this post Link to post Share on other sites
ebinmaine 81,282 #14 Posted August 18, 2024 13 minutes ago, Sparky said: Great! Was just about to start looking em up. I’ll do the measurements and hole size I guess. Keep us posted Share this post Link to post Share on other sites
cod 137 #15 Posted August 18, 2024 I just found this with a search for 90-643: https://www.amazon.com/Oregon-90-643-Replacement-Mower-Blade/dp/B0018U2F04 Perhaps Gator sold them to Oregon and they make a copy. There were a bunch of other hits as well, so take a look when you have a moment. Share this post Link to post Share on other sites
lynnmor 9,081 #16 Posted August 18, 2024 1 hour ago, cod said: I just found this with a search for 90-643: https://www.amazon.com/Oregon-90-643-Replacement-Mower-Blade/dp/B0018U2F04 Perhaps Gator sold them to Oregon and they make a copy. There were a bunch of other hits as well, so take a look when you have a moment. Amazon says unavailable, Google the Oregon 90-643 for other options. Share this post Link to post Share on other sites
Lee1977 7,813 #17 Posted August 19, 2024 21 hours ago, cod said: I just found this with a search for 90-643: https://www.amazon.com/Oregon-90-643-Replacement-Mower-Blade/dp/B0018U2F04 Perhaps Gator sold them to Oregon and they make a copy. There were a bunch of other hits as well, so take a look when you have a moment. Gator blades are made by Oregon it's there blade trade name. I have a couple of sets for a 48" deck I use for leafs. Share this post Link to post Share on other sites
cod 137 #18 Posted August 19, 2024 20 hours ago, lynnmor said: Amazon says unavailable, Google the Oregon 90-643 for other options. Sorry guys. I was in a hurry and didn't look as closely as I should have. That said, here's another link and these folks appear to have them : https://www.agrisupply.com/toro-wheelhorse-mower-blade/p/58033/ These are the Oregon blade that Lee1977 mentions. I think mine are all Oregons as well. Share this post Link to post Share on other sites
rjg854 13,454 #19 Posted August 19, 2024 @Sparky I have a set of those on the shelf that I used on a 42" deck until I got the recycler insert the deck was missing. I'm almost positive that's where they came from. Share this post Link to post Share on other sites
