peter lena 9,782 #1 Posted August 17, 2024 https://www.denniskirk.com/moose/plow-blade-skid-4501-0702.p519845.prd/519845.sku?trk_msg=BODLQOFFQ1TKN3QVUJR1PORF8G&trk_contact=4UPCIPTJ6JEVI02EQULBVPKMPK&trk_sid=6FGN8N2AO10L31C69SM4J1FGI0&t , very easy to bolt on a angular steel corner brace , to lower plow , plow carriage bolt point , add this and a vertical coil spring , to let slide work / adjust for your set up . just a suggestion , might also look up these pre bent , shelf mount connections ,ZAB205 / ZAB 202M , is magnetized , makes a very solid mount point , better , dare to explore ,paint it red , pete 1 1 Share this post Link to post Share on other sites
peter lena 9,782 #2 Posted August 17, 2024 @ at 854 @ @ pwl216 , those bracket ends ard drop forged on multi ton presses , really bombproof for a add on / connection point , add a compression spring on the , blade skid , and you can have consistent plowing , also like a lubrication finish on my blades , like adding HP , with increased slide off , also back cut your intended clearing so you have a place to go to . personally plow with the sun, move snow to where it will melt , also reduces ice on driveway . pete Share this post Link to post Share on other sites
