MSZ40 7 #1 Posted August 13, 2024 (edited) Hello, long time wheel horse owner, started with a used B-80, sold to family member to purchase a new 312-8 in 1996. Divorce seperated me from that one and 10 years ago I bought a used 314-8 with 42 side discharge deck. Spindles are noisy and need rebuild. Can't find any tag or part number on deck so looking to get correct spindle bearings. This 3 balde deck is not original deck either. Any help appreciated. Also have a snow blade and many parts like new for an un-used mold board plow. Thx Mike Edited August 13, 2024 by MSZ40 Share this post Link to post Share on other sites
daveoman1966 3,839 #2 Posted August 13, 2024 42" deck--- Model # on the deck? OR--- Do the top pulleys have a key-way slot in them or not? Take off one of the top nuts to see. OR----what is the dia of the TOP spindle shaft---3/4" (bng pair # 106084 & #106085) or 5/8" (two # 109966). I ask b/c there are 2 spindle styles of the 42" deck and bearing are different. Share this post Link to post Share on other sites
MSZ40 7 #3 Posted August 13, 2024 thank you for the reply..I will check later this week and give you the info you need to help me! Thx MSz Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,441 #4 Posted August 13, 2024 Here are the possibilities Mower DNA 42" side discharge 1966-1967 model RL-426 replaced by 1968 model 5-1421 1969 model 5-1422 1970 model 5-1423 1971 model 5-1000 1971-1972 model 5-1001 1973-1974 model 5-1010 1975 model 5-1011 1975 model 5-1012 1976 model 65-42MS01 - Online Toro parts illustration is the 48" SD deck 1976 model 65-42MS02 - Online Toro parts illustration is the 48" SD deck 1977 model 75-42MS01 - These 42" side discharge decks all use blades with 5/8" x 3/4" double-D center hole unless the spindles have been upgraded (Do not have operator manual) -------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- These decks all use blades with a 3/4" center hole. 1977 model 75-42MS02 replaced by (Do not have operator manual) 1978 model 85-42MS01 (Do not have operator manual) 1979 model 95-42MS00 (Do not have operator manual) 1979 model 95-42MS01 (Do not have operator manual) 1980 model 05-42MS01 (Have operator manual) 1981-1983 model 05-42MS02 1984 model 05-42MS03 - Last year for bearings with 3/4" ID 1985 model 05-42MS04 - First year for bearings with 17mm ID unless older spindles were updated. 1986-1988 model 05-42MS05 1989 model 15-42SC01 1990 model 15-42SC02 1990-1992 model 15-42SC03 1993-2007 and 2009-2012 model 78345 - These decks all use blades with a 3/4" center hole. Note - 17mm is .669" 1 Share this post Link to post Share on other sites
Lee1977 7,185 #5 Posted August 14, 2024 If it has 5/8" nuts on top of the mower spindles the bearings are metric 6203 ( 40mm OD 17 mm ID and 12 mm thick.) That is what should be on a 314-8 if it's the same model deck. The older decks with 3/4" nuts on top of the spindles also used a 6203 bearing with ( 40mm OD 3/4" ID and 12 mm thick. ) The old Double D spindles have a 3/8" bolt on top of the spindle with a compression washer. Blades and compression washers are hard to find for the old Double D decks and suggest newer metric spindles. All three types will bolt on I have had all three on my deck in the last 46 years. 1 Share this post Link to post Share on other sites
MSZ40 7 #6 Posted August 14, 2024 It appears the top of one of the outer spindle shafts is 5/8" not 3/4", although I did not check it with a caliper. There is a sticker on the trailing end of the deck that may offer some info but nothing I can decipher. Thx, Mike Share this post Link to post Share on other sites
