Retired Wrencher 6,792 #26 Posted August 8, 2024 11 hours ago, squonk said: Unless you want " Original" to satisfy the OHHH and AHH guys, the judges at the WH " Concours D' Elegance " show or it's a recoil no battery tractor it makes no sense to put on an an old ready to warp and leak again metal pump. Go electric. No Mike. I do not care to much what it looks like. With the start /gen tractors probably hide under the tank mount. Share this post Link to post Share on other sites
Retired Wrencher 6,792 #27 Posted August 8, 2024 16 hours ago, pfrederi said: I have used Aircraft spruce as a source also you can use Amazon. I have been using the 1.5 - 4.0 PSI others prefer the 1-2 psi (since your tank is higher and closer 1-2psi should work fine) Facet pumps are made in USA Elmira NY Paul thanks for the info. Looks like I will go with the #60304 and get it Aircraft Spruce seems to be the place to get it. Others where more expensive. Share this post Link to post Share on other sites
