8ntruck 7,777 #1 Posted August 4, 2024 (edited) Going to take care of some surface rust on a battery tray. Figuring on starting with a baking soda wash to neutralize any remaining battery acid follow up with a wire brush to get to bare metal. What have you folks used on your battery trays? Think a spray on truck bed liner would be a good choice? Edited August 4, 2024 by 8ntruck Share this post Link to post Share on other sites
ebinmaine 72,414 #2 Posted August 4, 2024 We've always just painted them. It'll be interesting to see other answers. 1 Share this post Link to post Share on other sites
Goldnboy 1,027 #3 Posted August 4, 2024 15 minutes ago, ebinmaine said: We've always just painted them. It'll be interesting to see other answers. Rattle can paint 2 Share this post Link to post Share on other sites
squonk 43,729 #4 Posted August 4, 2024 Rattle paint then a sheet of rubber to help with vibration 4 2 Share this post Link to post Share on other sites
Handy Don 13,977 #5 Posted August 4, 2024 41 minutes ago, squonk said: Rattle paint then a sheet of rubber to help with vibration I think you mentioned this once before and I adopted the idea and then added a rubber strip to the cross-bar as well 3 1 Share this post Link to post Share on other sites
ebinmaine 72,414 #6 Posted August 4, 2024 51 minutes ago, squonk said: Rattle paint then a sheet of rubber to help with vibration 9 minutes ago, Handy Don said: I think you mentioned this once before and I adopted the idea and then added a rubber strip to the cross-bar as well I've done similar with wood strips. Wasn't because I wanted a vibration reduction or to protect the battery. That was a good side effect though. 1 Share this post Link to post Share on other sites
953 nut 59,757 #7 Posted August 4, 2024 Spray paint and a rubber pad sounds like a good enough ideas, or you could prime it and then use plasti dip coating. 2 Share this post Link to post Share on other sites
WHX?? 51,696 #8 Posted August 5, 2024 While we're at it. Battery Tray Repair - Restorations, Modifications, & Customizations - RedSquare Wheel Horse Forum Little trick @Achto taught me. Use anglle instead of strap. Little more beefier. 2 Share this post Link to post Share on other sites
squonk 43,729 #9 Posted August 5, 2024 10 minutes ago, WHX?? said: While we're at it. Battery Tray Repair - Restorations, Modifications, & Customizations - RedSquare Wheel Horse Forum Little trick @Achto taught me. Use anglle instead of strap. Little more beefier. It helps to keep the battery in when popping wheelies at the Big Show! 1 Share this post Link to post Share on other sites
