Torrence20 23 #1 Posted August 2, 2024 I have a wheel horse tiller I’d like to fix up. I ordered the main bearings and seals but I would like to go ahead and replace all the other bearings in it while I’m at it. The model plate is long gone. It’s 36” from what I can tell. Would anyone have part numbers for the remaining bearings? Share this post Link to post Share on other sites
oliver2-44 10,979 #2 Posted August 2, 2024 Could you post some pictures to help identify it Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,750 #3 Posted August 2, 2024 Click on the picture in the link to see a list of tillers and some of their characteristics. May help you identify what you have. Share this post Link to post Share on other sites
peter lena 9,471 #4 Posted August 2, 2024 @Torrence20 what ever you do , use a CLIMBING GEAR OIL / LUBE , LUCAS has them , the fling / spray , has been very effective in all my related gear units , ease of operation , dramatic noise reduction , also pay attention to related belt drive pulleys , linkage for ease of movement . pete 1 Share this post Link to post Share on other sites
peter lena 9,471 #5 Posted August 3, 2024 @Torrence20 very often refer to anything related to , a failure point , personally do a regular look see , on my units , check for anything , another regular thing I do , is to get after anything thats not working as it should . have regularly ,made a change at point of issue , and regularly verify how it reacting to the change made , because I have a regular , inspection , anything thats not working as it should , stands out . when I shut down my , tractor , always top off tank , always add STA BIL , 1 ounce , to that fuel , always check trans fluid , later check oil / condition , never let something , build up , that will be your mind set , that can quickly turn into a number of uncorrected problems . been doing this over 40 years , lots of issues eliminated , realise everyone has a different way of dealing with repetitive problems , personally , thats what I want , leads me right to the problem , and the change of it , pete Share this post Link to post Share on other sites
