Ozz 7 #1 Posted July 29, 2024 Hi wheelhorsemen, I have a 312-8 WH that has a pretty beat up deck. I need the smaller deck (37"???) but do not know if they all interchange or not. I would like a rear discharge. Any info would be appreciated. Thanks Share this post Link to post Share on other sites
Sparky-(Admin) 26,206 #2 Posted July 29, 2024 A small rear discharge deck would be a 36”. The 37” deck is a side discharge. All of the garden tractor decks made from 1973 and up will work with your 312. 1 Share this post Link to post Share on other sites
Ozz 7 #3 Posted July 29, 2024 Awsome, thanks for the quick reply. Any sources to some decks? Share this post Link to post Share on other sites
Sparky-(Admin) 26,206 #4 Posted July 29, 2024 1 hour ago, Ozz said: Awsome, thanks for the quick reply. Any sources to some decks? My advice: place a wanted ad in the classifieds here and include your location. I’m a big fan of the 36” RD decks! I run one here often. Good luck! 1 Share this post Link to post Share on other sites
Lee1977 7,750 #5 Posted July 30, 2024 (edited) The 37" deck needs the 6" front wheels If your 312 has 8" front wheels with 16 x 650 x 8 tires the right front wheel will hit the deck as the 37 deck is angled to the front.. Edited July 30, 2024 by Lee1977 1 Share this post Link to post Share on other sites
Ozz 7 #6 Posted July 30, 2024 (edited) I found this locally (Georgia), will this work? 42" Edited July 30, 2024 by Ozz Share this post Link to post Share on other sites
peter lena 10,013 #8 Posted July 30, 2024 @Ozz agree that the deck will work , its all the related , movement functions that are critical . first bottom side look , is it crusty / rusty ? baffling loaded with build up ? blade condition ? how easily do the spindles . blades move ? deck looks complete , could still need a refresh , rotational movement issue , rough , usually indicates bearing issues , if deck belt is frayed , heavily worn , probably related bearing issues . then again you might luck out , not as much as possible , for use . let us know . pete 1 Share this post Link to post Share on other sites
