Hoosierhorser 0 #1 Posted July 27, 2024 I have an 87 3128 runs pretty good however lately it seems to bog down in heavy grass....... can I do something to keep up the rpm. Hoosierhorser Share this post Link to post Share on other sites
ri702bill 13,075 #2 Posted July 27, 2024 (edited) Welcome!! A few things come to mind.... Is the air filter clean? One that is visably dirty on the inside will cut the air flow to about half. Cutting deck height? You may need a higher setting. Are the blades sharp AND properly installed?? Is the belt from the PTO in good condition and properly tensioned? A slipping belt slows down the blade speed. PTO - are you using the larger of the two pulleys? That affects belt speed if wrong.Did you try WOT (wide open throttle) and a lower gear?? Is the governor working properly? All of these individually can affect the cut - a combination of 2 or more is a problem. Edited July 27, 2024 by ri702bill 2 Share this post Link to post Share on other sites
