Toolmanbill 44 #1 Posted July 21, 2024 Can anyone tell me where this brake spring attaches to?mine must have broken and I can’t tell where it attaches to.listed on the drawing is part #40. Share this post Link to post Share on other sites
peter lena 10,013 #2 Posted July 21, 2024 @Toolmanbill look carefully at the lower end of , each connection , probably , rust or grass packed small hole , another perfect opportunity , is to LUBRICATE ANY / ALL LINKGE / MOVEMENT POINTS ! like a penetrating oil first / make the rust run out , then an aerosol spray ,extension tube RED GREASE , lots to learn in related linkage areas , should be easy to move , pete Share this post Link to post Share on other sites
rmaynard 17,527 #3 Posted July 21, 2024 (edited) 1 hour ago, Toolmanbill said: Can anyone tell me where this brake spring attaches to?mine must have broken and I can’t tell where it attaches to.listed on the drawing is part #40. Spring attaches from the small hole in ratchet (23) to a small hole at the bottom of the dash tower. This picture is from a B-100 8-speed, looking down through the shift pattern plate. You didn't specify what model you are working with, but this should give you some frame of reference. Edited July 21, 2024 by rmaynard 2 Share this post Link to post Share on other sites
Toolmanbill 44 #4 Posted July 23, 2024 Thanks for the info guys.much appriciated Share this post Link to post Share on other sites
