Tom Scott 0 #1 Posted July 19, 2024 Hooking up a snow plow on a 520h cannot see how to hook up lift do you hook to linkage with chain or to flat arm coming down Share this post Link to post Share on other sites
ebinmaine 77,564 #2 Posted July 19, 2024 Do you have the extension kit for the rear of the snow plow frame? 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,017 #3 Posted July 20, 2024 Here is the 1994 manuals Share this post Link to post Share on other sites
Tom Scott 0 #4 Posted July 20, 2024 I downloaded book but my attach point does no line up with the mower deck lift it looks like it hooks up on other side lift point Share this post Link to post Share on other sites
lynnmor 8,651 #5 Posted July 20, 2024 3 hours ago, Tom Scott said: I downloaded book but my attach point does no line up with the mower deck lift it looks like it hooks up on other side lift point Is your problem front to rear or left to right? The 520H has the swept front axle so a snow plow needs to be moved forward so the tires do not hit it. If you don't have the very rare plow made to fit, you need the kit to extend the plow forward. Here is a link to one such kit. Share this post Link to post Share on other sites
Handy Don 16,024 #6 Posted July 21, 2024 On 7/19/2024 at 5:49 PM, Tom Scott said: Hooking up a snow plow on a 520h cannot see how to hook up lift do you hook to linkage with chain or to flat arm coming down Default is by chain to the intermediate lift bar and then a solid link from the lift bar to the plow frame. However, a solid link direct from the rock shaft arm to the plow frame is an option. The chain relies on the plow’s weight for scraping (i.e. no down force is possible) The solid link does have the option of downforce, but with a 520’s lift control (i.e. it does not have a “float” position) it is quite a trick to modulate height/pressure (too hard and you wear out the plow and driveway; too soft and you miss stuff) Share this post Link to post Share on other sites
