HauslerosaFarms 13 #1 Posted July 15, 2024 Looking for a rebuild or a metal type replacement fuel pump for a 1964 kohler k241 engine. Share this post Link to post Share on other sites
rjg854 12,842 #2 Posted July 15, 2024 nowandthen.com Share this post Link to post Share on other sites
WHX?? 54,963 #3 Posted July 15, 2024 Stay away from the plastic ones like the plague if possible. Its a crap shoot whether or not you are getting a working one or how long it will last. Otherwise Randy has a good source for rebuild kits with then & now auto.. Interestingly enough at a recent show a guy had a Ed Dog bucket filled with metal ones of all types. $10 a pump. If I didn't have my head up my rear I shoulda got some for distribution here, Share this post Link to post Share on other sites
953 nut 64,110 #4 Posted July 15, 2024 Lincoln at A-Z Tractor parts can probably fix you up with one. https://www.a-ztractor.com/ Give him a call. Share this post Link to post Share on other sites
HauslerosaFarms 13 #5 Posted July 16, 2024 Thanks guys! Yes… I wish you would’ve bought the bucket. I probably would’ve bought a handful😊 1 1 Share this post Link to post Share on other sites
WHX?? 54,963 #6 Posted July 16, 2024 10 hours ago, HauslerosaFarms said: would’ve bought the bucket. Chances are pretty good I will run into him at future shows and I will. Guy with the red enclosed & all the used Kohler parts @Achto. Guy I got the coil & dip stick for Busty from ...Think it was at Pickett show? Share this post Link to post Share on other sites
Achto 30,997 #7 Posted July 16, 2024 11 minutes ago, WHX?? said: Guy I got the coil & dip stick for Busty from ...Think it was at Pickett show? I believe that's where we saw him. Actually thought he was at Portage last week too. 1 Share this post Link to post Share on other sites
WHX?? 54,963 #8 Posted July 16, 2024 9 minutes ago, Achto said: he was at Portage last week Yep that's where I stumbled past the pumps. 1 Share this post Link to post Share on other sites
wallfish 19,287 #9 Posted July 17, 2024 (edited) Most of those OLD pumps just have the check valve disks. (Not the POD type) Open it up, DON'T loose the springs, clean the disks and flip them over, clean the seat where those disks sit on, re-assemble. You can verify the check valves are good with a piece of hose connected to the output and try to blow backwards against the normal flow of fuel. Should be minimal air movement. If so, Re-install it and you're good to go. Depending upon the tractor, if the gas tank is higher than the carb, bypass the pump. The pump is needed for hills and such which could put the tank lower. Edited July 17, 2024 by wallfish 3 1 Share this post Link to post Share on other sites
HauslerosaFarms 13 #10 Posted July 21, 2024 Hey guys just wanted to provide you with an update. The diaphragm in the fuel pump had been dry for so long it began to crack. I replaced it with a diaphragm I ordered from isavetractors.com and it now runs flawlessly. I will still be on the lookout for parts here and there as I would love to keep this engine as original as possible. Thanks! 1 1 Share this post Link to post Share on other sites
