TJN 18 #1 Posted July 11, 2024 Hi Folks, I priced 2 air cleaner to block, carb to block, fuel pump to block and 4 "center" fuel pump gaskets. The vendor checked with the supplier and came up with an $85.00+ cost! Where do you get your gaskets and what do you think of "my" prices? Thanks, Tom. (TJN) Share this post Link to post Share on other sites
Skwerl58 761 #2 Posted July 11, 2024 I get mine from various suppliers. A local auto parts store, isave tractors, ebay and Amazon. Ordered some seals from vendors here on RedSquare. Share this post Link to post Share on other sites
953 nut 59,784 #3 Posted July 11, 2024 10 hours ago, TJN said: fuel pump to block and 4 "center" fuel pump gaskets. Then and Now is a good supplier for fuel pump parts. https://www.then-now-auto.com/kohler-fuel-pumps-2/ 1 Share this post Link to post Share on other sites
rmaynard 16,290 #4 Posted July 11, 2024 What engine are you working on? Share this post Link to post Share on other sites
pfrederi 18,638 #5 Posted July 11, 2024 I got a gasket set from Red Barn for a K-341. Oil pan gasket sticks out all the way around. Even the head gasket sort of peaks out at one corner. Oil pan gasket was marked Made in USA...Guess Laity control is slipping... Share this post Link to post Share on other sites
TJN 18 #6 Posted July 11, 2024 2 hours ago, rmaynard said: What engine are you working on? 2 hours ago, rmaynard said: What engine are you working on? It's a Kohler, 12hp, k301S, 1974 on a "no name 42" cut Horse. Thanks, Tom Share this post Link to post Share on other sites
TJN 18 #7 Posted July 11, 2024 2 hours ago, pfrederi said: I got a gasket set from Red Barn for a K-341. Oil pan gasket sticks out all the way around. Even the head gasket sort of peaks out at one corner. Oil pan gasket was marked Made in USA...Guess Laity control is slipping... Thanks for the info! Tom Share this post Link to post Share on other sites
TJN 18 #8 Posted July 11, 2024 2 hours ago, pfrederi said: I got a gasket set from Red Barn for a K-341. Oil pan gasket sticks out all the way around. Even the head gasket sort of peaks out at one corner. Oil pan gasket was marked Made in USA...Guess Laity control is slipping... Thanks for the info! Tom Share this post Link to post Share on other sites
TJN 18 #9 Posted July 11, 2024 2 hours ago, pfrederi said: I got a gasket set from Red Barn for a K-341. Oil pan gasket sticks out all the way around. Even the head gasket sort of peaks out at one corner. Oil pan gasket was marked Made in USA...Guess Laity control is slipping... Thanks for the info! Tom Share this post Link to post Share on other sites
TJN 18 #10 Posted July 11, 2024 4 hours ago, 953 nut said: Then and Now is a good supplier for fuel pump parts. https://www.then-now-auto.com/kohler-fuel-pumps-2/ Thanks much for the response! I have learned that the pump is out of print. The gaskets(4/5)installed when rebuilt 3 years ago are leaking. Gaskets appear to be unavailable. I' ll try your source. Replacement is Plastic pump. Or I could go vacuum or electric. I would prefer stock, but not available. Thanks again for the info! Tom 1 Share this post Link to post Share on other sites
