Countdown To Christmas!
IthacaJeff
setting the points
IthacaJeff
WH'ers;
Okay, perhaps my most stupid question ever (I'm sure my wife would disagree!),
but here goes. . .
I'm wanting to check the gap on my breaker points on my 416 with a Kohler K341,
but I don't know where it is. The wires from the coil go to the condenser bolted to
the engine, but then the wires snake under and into the blower housing. Do I need
to take off the engine baffles to set my ignition timing?
Thanks,
Jeff in Ithaca
Kelly
Sitting on the tractor the right front of the engine is a tin box with a wire going in to it, and two reg. screws holding it on your points are in there.
IthacaJeff
Kelly,
Sorry for the late thanks, but I've been away from my computer all week. I'll
check it out later today. . . thanks again.
Jeff
FrankinWNY
Hi Jeff, you may be looking at the wire that goes to the magneto, I think the 416 came with the Magnum engine, not the K-341. the Magnum does not have points, condensor, and coil. Unless you have removed the flywheel, there is nothing to set.
Frank in WNY :scratchead:
WHC-125
Frank, Wheel horse made 3 different motor setups for the 416-8. One is a Kohler 16 hp K-341, another is a Kohler 16 hp M-16, and a Onan P16.
IthacaJeff
Frank:
Yup, it is a K341 with a coil. My 310 with an M10 does not have a coil, which is
one reason I don't have experience with the type of ignition on the K341.
By the way, the plow set up you sold me several years ago is going strong on
the 310-8. I just used it to help scape down grass to create a level and grass-free
spot for a post frame shed I'll be building on some new land we have. Not
really the best tool for the job, but ya' gotta use what ya' got.
Thanks all,
Jeff
