osubrutus1 3 #1 Posted June 28, 2024 I have a C-175 and have had to replace the cam plate several times over the years. I especially have issues when the tractor is on a hill with a bit of a twist to it, the lever jams because the cam block pin pulls out of the cam block then it is stuck in reverse. the only thing I can do at that point is turn off the tractor. I would appreciate any advice or modifications that would help. Share this post Link to post Share on other sites
Ed Kennell 46,608 #2 Posted June 28, 2024 Check the frame and bolts that attach the frame to the transmission. 5 Share this post Link to post Share on other sites
ri702bill 12,502 #3 Posted June 28, 2024 16 minutes ago, Ed Kennell said: Check the frame and bolts that attach the frame to the transmission. A bad "F" plate equals a bad behaving tractor... does it grunt & groan and wiggle like an inchworm??? Like this one did????? 4 Share this post Link to post Share on other sites
osubrutus1 3 #4 Posted June 28, 2024 I cecked all bolts , plates and frame. All are tight and no cracks 2 Share this post Link to post Share on other sites
Ed Kennell 46,608 #5 Posted June 29, 2024 (edited) 20 hours ago, osubrutus1 said: the cam block pin pulls out of the cam block Can you post a picture of this pin ? This is one of my Eaton 1100 cam plates. I don't see how it would be possible for a pin to pull thru the cam plate. Edited June 29, 2024 by Ed Kennell 1 Share this post Link to post Share on other sites
peter lena 9,951 #6 Posted June 29, 2024 @osubrutus1 only a suggestion , take advantage of the failure point , get a helper to visibly look things over at that point. would also like to see a related picture to hang up . have seen so many , rusty / crusty . cracked / binding areas . think your twist frame / linkage related set up is your answer. that pin pull out is your lead, sheared bolt / related to twist . another set of eyes , always helps , pete 1 Share this post Link to post Share on other sites
pfrederi 20,878 #8 Posted June 30, 2024 Some early C-175 had Sunstrands. Is that what you have (Tranny filter on right side of transaxle??) If so check for any wiggle in the cross shaft #79 the bushing # 54 maybe worn out. The pic you posted is #77. Any cracks in the plastic slider #60 pic 2 4 Share this post Link to post Share on other sites
Ed Kennell 46,608 #9 Posted June 30, 2024 4 hours ago, pfrederi said: Some early C-175 had Sunstrands. Thanks Paul, I thought we were dealing with an Eaton. Share this post Link to post Share on other sites
peter lena 9,951 #10 Posted July 2, 2024 @osubrutus1 agree with others on possibilities , something you might try is to duplicate the angular twist that starts the problem , couple of floor jacks , also another set of eyes to spot anything being pulled off point . not had to deal with your problem , but REPEDITAVE PROBLEM IS YOUR BEST TRACKING TO IT . expect to change out what's there , often change out a movable linkage failure to a heim joint , thinking a male / female screw in , for strength . smooth action . heim joints come in many types . sizes . just my first thought , they have eliminated problem swivel connections , pete Share this post Link to post Share on other sites
osubrutus1 3 #11 Posted July 23, 2024 SO, originally I checked the bolts and looked at the front side if the plate. When I had more time, I removed the transaxle assembly and found the crack and also that it had been welded before I had it. Can this plate be replaced? Share this post Link to post Share on other sites
