John2189 552 #1 Posted June 24, 2024 Is there an id plate on the decks? I think it is a 42” but not sure. I know…. Measure it. Just wondering what blades it takes Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,751 #2 Posted June 24, 2024 1 hour ago, John2189 said: Is there an id plate on the decks? Once upon a time I think it is a 42” but not sure. I know…. Measure it. Size is the width of cut. The 42" decks have the adjuster for the rear wheels on the right side. Just wondering what blades it takes You need to remove the blades from each spindle to see what center hole they have. They went from 5/8"x3/4" double-D to 3/4" round. Share this post Link to post Share on other sites
John2189 552 #3 Posted June 25, 2024 58 minutes ago, gwest_ca said: The adjusting handle is on the right side Share this post Link to post Share on other sites
953 nut 62,212 #4 Posted June 25, 2024 Blade size and type of attachment is not the same for all Wheel Horse decks. Hire is a list of deck manuals that may help you find what you are looking for. https://www.wheelhorseforum.com/search/?q=1984&quick=1&type=downloads_file&nodes=18 Share this post Link to post Share on other sites
John2189 552 #5 Posted June 25, 2024 4 hours ago, 953 nut said: Blade size and type of attachment is not the same for all Wheel Horse decks. Hire is a list of deck manuals that may help you find what you are looking for. https://www.wheelhorseforum.com/search/?q=1984&quick=1&type=downloads_file&nodes=18 Thanks, I did measure it this morning and it is a 42”. No model or serial number that I can find Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,751 #6 Posted June 25, 2024 There is also a side and rear discharge. For side discharge 6693 blade replaced by 100200 3-blade kit and no longer available (Hole 5/8in.x3/4in. Double-D) 106077 replaced by 106636 3-blade set (3/4" round hole) For rear discharge 106586 3-blade set replaces 105837 blade and no longer available (5/8" x 3/4" double-D center hole) 106079 and 106108 blades replaced by 106635 3-blade set (3/4" center hole) Share this post Link to post Share on other sites
