23 Reo 234 #1 Posted June 23, 2024 What oil filter do you recommend for a 520H ? Share this post Link to post Share on other sites
lynnmor 8,623 #2 Posted June 23, 2024 Onan 122-0800 or Fleet-guard LF3339 1 Share this post Link to post Share on other sites
WHX?? 54,976 #4 Posted June 24, 2024 I have Napa 1764 in my files but also 1762 & 1374. There is a long and a short filter and one has the wrench hex on the end. Counter guy should be able to help sort out. 3 hours ago, lynnmor said: Onan 122-0800 or Fleet-guard LF3339 Are good numbers too. Napa 1410 on the Hydro oil filter. 1 Share this post Link to post Share on other sites
Wild Bill 633 907 #5 Posted June 24, 2024 (edited) Onan 1120800 crosses over to a Wix 51762, 4.575" long. You may also want to consider adding a FilterMag to both the oil and hydro filters along with magnetic drain plugs. Edited June 24, 2024 by Wild Bill 633 1 1 Share this post Link to post Share on other sites
WHX?? 54,976 #6 Posted June 24, 2024 42 minutes ago, Wild Bill 633 said: Onan 1120800 crosses over to a Wix 51762, 4.575" long. You may also want to consider adding a FilterMag to both the oil and hydro filters along with magnetic drain plugs. 1764 might be the longer one then. The longer one just fits in ther. I have been known to put a cow rumen magnet on my filters. 1 Share this post Link to post Share on other sites
artfull dodger 440 #7 Posted June 25, 2024 And if yours is missing the rubber grommet that goes on the cylinder tin to help seal it to the oil filter body, replace that as well. VERY important to keeping the air flow for that cylinder going over the jug and head fins. 1 Share this post Link to post Share on other sites
lynnmor 8,623 #8 Posted June 25, 2024 6 hours ago, artfull dodger said: And if yours is missing the rubber grommet that goes on the cylinder tin to help seal it to the oil filter body, replace that as well. VERY important to keeping the air flow for that cylinder going over the jug and head fins. I got it from a good source that a missing seal can reduce the air flow by up to 30%. When playing around with alternate brands and part numbers of oil filters, be sure to check the fit of that seal. 1 1 1 Share this post Link to post Share on other sites
artfull dodger 440 #9 Posted June 25, 2024 Correct, and that cylinder already has a challenge to cooling with the belt guard blocking the output side of the cooling air to some degree. The valve adjustments and keeping the flywheel side of the cylinder fins super clean are highly important as well. More so on the Onan vs other brands. But its a great practice to do on other brands other than valve adjustment. 1 Share this post Link to post Share on other sites
23 Reo 234 #10 Posted June 27, 2024 What is the best place to put the cow rumen magnet on the filter? I've had good luck with magnets on drain plugs. Share this post Link to post Share on other sites
Wild Bill 633 907 #11 Posted June 27, 2024 1 hour ago, 23 Reo said: What is the best place to put the cow rumen magnet on the filter? The first stomach. LOL 1 2 Share this post Link to post Share on other sites
WHX?? 54,976 #12 Posted June 28, 2024 4 hours ago, 23 Reo said: What is the best place to put the cow rumen magnet on the filter? I've had good luck with magnets on drain plugs. Anywhere iron particles will find it. Could use a couple nice thing about them reusable. 1 Share this post Link to post Share on other sites
