SnoJet 20 #1 Posted June 17, 2024 Hello and thank you for any help. My 416H lost power to the coil. It will turn over but will not start. If I run a jumper wire from the battery to the coil post it will start and run fine. I have checked and bypassed the seat and PTO switches. Any other advice? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,320 #2 Posted June 17, 2024 Model number and serial number would help. Share this post Link to post Share on other sites
SnoJet 20 #3 Posted June 17, 2024 model 73421 serial 3900541 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,320 #4 Posted June 17, 2024 Download this file. One schematic shows what is required for ignition. 1 Share this post Link to post Share on other sites
ri702bill 12,386 #5 Posted June 17, 2024 I believe that the 416H has that troublesome-over-time 9 pin connector...... probe the coil power wire on both sides of the connector with the key "ON" 1 Share this post Link to post Share on other sites
SnoJet 20 #6 Posted June 17, 2024 Bingo! 9 pin connector was the culprit. Pulled it apart and reconnected and it works! Thank you! 2 1 Share this post Link to post Share on other sites
Lane Ranger 12,023 #7 Posted June 17, 2024 You also have to watch for gnawed coil wires under the tins from mice. I had a 314 with that problem! Just had to purchase a new coil. 1 Share this post Link to post Share on other sites
