RandyT 1 #1 Posted June 8, 2024 I need help adjusting the deck height on my 312-8. I read all the threads associated with it, but still haven’t figured it out. My deck cuts too low. If I raise the gauge will in the back the front stays down and of course you get a uneven cut when lowering the wheels in the back how does it adjust the front of the deck? 1 Share this post Link to post Share on other sites
ebinmaine 80,088 #2 Posted June 8, 2024 Can you please post some pics of the deck/tractor at full up and full down positions? Maybe the lift link(s) are too short underneath? Share this post Link to post Share on other sites
lynnmor 8,971 #3 Posted June 8, 2024 Download the manual for your deck and completely follow the installation instructions. You will see that the deck wheels need to be set to the position that raises the deck the most, and the deck needs to be leveled using an adjustment at the center rear of the deck. There should be a model number on deck, if not post a photo so we can help you find the correct manual. 1 4 Share this post Link to post Share on other sites
