Waylinrayls 0 #1 Posted June 8, 2024 My 1067 has got a 10 horse kholer on it and it has electrical problems Share this post Link to post Share on other sites
oliver2-44 11,758 #2 Posted June 8, 2024 You’ve come to the right place. Lots of friendly helpful people here. Tell more about your tractor and yourself n Is it new to you or was it running ok and just started having a problem? Please describe what it’s doing or not doing? To help members help you, what have your tried so far. Do you have a volt/ohm test meter or a test light to trouble shoot with? 1 Share this post Link to post Share on other sites
953 nut 69,478 #3 Posted June 8, 2024 The wiring on a 1967 model is very simple to follow. The attached diagram should be helpful. Share this post Link to post Share on other sites
rjg854 13,373 #4 Posted June 8, 2024 (edited) not knowing what your problem is if you think electrical, start by checking your wiring, is everything clean and tight? Do you have spark? Edited June 8, 2024 by rjg854 add Share this post Link to post Share on other sites
