Ed Kennell 47,388 #26 Posted June 7, 2024 (edited) Could be the camera angle, buy that inner hyd pump belt looks too wide for the pulley. Should be 3/8x48. BTW, I was mistakenly looking at the 1045 manual where I saw the 70" drive belt. The 1054 and 953 manual lists the 82" belt. Looking at this pic again, that belt looks fairly new. I'm wondering if the PO tried to install a new 1/2x82" transmission belt and had trouble getting it on the larger pulley and just put it on the smaller inner hyd pump pulley. Edited June 7, 2024 by Ed Kennell 1 Share this post Link to post Share on other sites
Dave E 37 #27 Posted June 7, 2024 49 minutes ago, Ed Kennell said: Could be the camera angle, buy that inner hyd pump belt looks too wide for the pulley. Should be 3/8x48. BTW, I was mistakenly looking at the 1045 manual where I saw the 70" drive belt. The 1054 and 953 manual lists the 82" belt. Yeah, I had my clean duds on this morning and was headed out to work so I couldn't quite figure that out. I thought maybe the belt slipped off the inner pulley? I bought a 1/2" x 47" at TSC this morning because I wasn't sure if tehe 1591 part number was 1/2" or 5/8"... this is the first I have seen 3/8" though. TS only had 1/2 and 5/8 belts and had no 5/8 x 47". Was hoping to replace both at once but if need be will just get the engine/drive working for now. Share this post Link to post Share on other sites
squonk 48,137 #28 Posted June 7, 2024 All kinds of WT's goin on. 953/1054 didn't come with an electric PTO either. 1 Share this post Link to post Share on other sites
Dave E 37 #29 Posted June 7, 2024 (edited) 21 minutes ago, squonk said: All kinds of WT's goin on. 953/1054 didn't come with an electric PTO either. Where are you seeing electric PTO? I'm still a newbie - says so in my status! (edit: seems that post promoted me to member, lol) Edited June 7, 2024 by Dave E Share this post Link to post Share on other sites
Dave E 37 #30 Posted June 7, 2024 Another place to get the Hydraulic which is indeed (.375") 3/8" x 48" : https://www.vbeltguys.com/products/1591-toro-or-wheel-horse-fhp-replacement-v-belt 1 Share this post Link to post Share on other sites
squonk 48,137 #31 Posted June 7, 2024 (edited) That big honkin pulley on the end with the wire hanging out (yellow circle.) Electric clutch PTO Should look like this: Edited June 7, 2024 by squonk Share this post Link to post Share on other sites
Dave E 37 #32 Posted June 7, 2024 Ok, I have no idea... anyone else? Share this post Link to post Share on other sites
Ed Kennell 47,388 #33 Posted June 7, 2024 9 minutes ago, Dave E said: Ok, I have no idea... anyone else? No idea why anyone would change the PTO to electric.. The instant on engagement is not good for the equipment and the wires are usually broken off too short to repair. IMO, the original PTO system shown on Mikes 953 pic was the best ever. No safety switches, easy to set the gap and pressure on the plate, and nothing to wear out. 3 Share this post Link to post Share on other sites
Dave E 37 #34 Posted June 7, 2024 9 minutes ago, Ed Kennell said: No idea why anyone would change the PTO to electric.. The instant on engagement is not good for the equipment and the wires are usually broken off too short to repair. IMO, the original PTO system shown on Mikes 953 pic was the best ever. No safety switches, easy to set the gap and pressure on the plate, and nothing to wear out. Ok, so I guess I am on the hunt for an original PTO, are the forum here and eBay the best places? I want simple and it looks like this is already a problem with the broken off wires... Share this post Link to post Share on other sites
Dave E 37 #35 Posted June 8, 2024 (edited) 20240608_053458.mp4 Gonna change oil and take plow off before I take her around the yard for.a spin. Started right up! Thanks for the encouragement all! Edited June 8, 2024 by Dave E 4 Share this post Link to post Share on other sites
Dave E 37 #36 Posted June 8, 2024 20240608_053458.mp4 Share this post Link to post Share on other sites
adsm08 5,149 #37 Posted June 8, 2024 On 6/6/2024 at 3:24 PM, Pullstart said: You might say I’m a fan of ‘em! Yeah, but there's that other guy here who goes nuts for them. Or so I've heard. 1 1 Share this post Link to post Share on other sites
953 nut 69,410 #38 Posted June 8, 2024 9 minutes ago, adsm08 said: Yeah, but there's that other guy here who goes nuts for them. Or so I've heard. I Resemble that Remark. 18 hours ago, Dave E said: Ok, so I guess I am on the hunt for an original PTO, are the forum here and eBay the best places? I want simple and it looks like this is already a problem with the broken off wires... You may be able to find one on or check with Lincoln at A-Z Tractor. https://www.a-ztractor.com/ This manual shows everything you would need for the manual PTO setup. Share this post Link to post Share on other sites
Dave E 37 #39 Posted June 8, 2024 3 minutes ago, 953 nut said: I Resemble that Remark. You may be able to find one on or check with Lincoln at A-Z Tractor. https://www.a-ztractor.com/ This manual shows everything you would need for the manual PTO setup. I think I have a line on one local. Will know later today. That pto manual is perfect. Thanks! 1 Share this post Link to post Share on other sites
Ed Kennell 47,388 #40 Posted June 8, 2024 Have you tried to drive it. Looking at that straight on picture of the belt. It does appear to be angled to the transmission rather than to the hydraulic pump. Share this post Link to post Share on other sites
Dave E 37 #41 Posted June 8, 2024 39 minutes ago, Ed Kennell said: Have you tried to drive it. Looking at that straight on picture of the belt. It does appear to be angled to the transmission rather than to the hydraulic pump. It drives but I'm thinking same. Will be getting into the belts later today to see what's really up. I have a new drive belt. Had to order the hydraulic. 2 Share this post Link to post Share on other sites
