sodbuster 1 #1 Posted August 31, 2009 I have a cub 147 with ags and want to swap the wheels off my jd 318 will they fit?? :scratchead: Share this post Link to post Share on other sites
Sparky-(Admin) 23,773 #2 Posted August 31, 2009 The tire size will probably not be a problem but the backspacing of the rim center will be the determining factor. You'll have to do a visual inspection to see if the spacing is the same or similar. Of course the spacing might not matter if there are no clearance issues like an under fender fuel tank. Mike.......... Share this post Link to post Share on other sites
