Jimmy Hoops
Wheel Horse 616z Belts
Jimmy Hoops
I'm trying to locate a list of belts with part numbers for my mower. I found a manual online but it only list one of three belts on this unit.
WHX??
:WRS:
Did you check with places like Parts Tree and such?
Maybe a Toro dealer?
Mid 90's Toro branded Z turn fellas.
Jimmy Hoops
9 minutes ago, WHX?? said:
:WRS:
Edited by Jimmy Hoops
Posted reply in the wrong place
Jimmy Hoops
The manual I found has a breakdown of the entire mower but it only lists one belt "V belt" but mine has three separate belts on it
gwest_ca
See 1 belt on a transmission page
See 1 belt on a pto page
See 2 belts on a mower page
What is the model number and serial number on the tractor? 14 possibilities
What is the width of cut of the mower and side or rear discharge? 3 possibilities
Jimmy Hoops
Hopefully this helps. I'm not sure about the width of the mower but it's a side discharge.
gwest_ca
Section 3 and 14 has 1 belt each
https://www.partstree.com/models/y1-16oe01-616-z-toro-zero-turn-mower-drive-unit-only-1989
Your mower is likely on this page. It will be a 38" or 42" side discharge. Will be an SY model and looks like the 38" has only 2 blades. Can not find the 1989 models but 1990 is likely the same.
https://www.partstree.com/models/05-38sy01-toro-38-side-discharge-mower-deck-1990
  • Excellent 2
gwest_ca
Transmission drive belt 116527 - (HA x 43.25" or 1/2" x 43.25")
Drive belt 116160 (Aftermarket replacements are 5/8" x 72") - Not in the belt chart
Spindle belt 116507 (Dimensions unknown) - Not in the belt chart
19 search results in our files for Y1-16OE01
https://www.wheelhorseforum.com/search/?q=Y1-16OE01&quick=1&type=downloads_file
Jimmy Hoops
Thank you. I'll have to do some more research.
Josh G
I am looking for the air cleaner assembly for my 616Z.  Any ideas where I can find a used or new assembly?  The plate is missing and everything.
Terry M
Welcome to RS!!!
best place to start is putting an ad in the classifieds wanted section…
have you tried Toro.com?
gwest_ca
1989?
Josh G
15 minutes ago, gwest_ca said:
1989?
Josh G
I have found the schematics but most has been discontinued
gwest_ca
Was hoping someone would know of a source or different application that used the same pieces.
