bardern 0 #1 Posted June 1, 2024 I have a 418a i have been un-MacGivering from years of prior tinkering. When i bought the unit the blade engagement works fine. How when i engage the pto it kills the engine. Any suggestions of where to look? The seat switch is long gone. I have little issue with the mechanical side of things but struggle mightily troubleshooting electrical Share this post Link to post Share on other sites
953 nut 68,154 #2 Posted June 1, 2024 There is a Dark Blue wire (or black with a dark blue tracer) going from the PTO switch and ignition switch "M" terminal to the Magneto. If is contacts electrical ground ( the frame or sheet metal) it will kill the ignition. Remove your battery and inspect that wire to see if the insulation has become frayed and makes contact when the PTO lever is moved. 1 Share this post Link to post Share on other sites
bardern 0 #3 Posted June 1, 2024 Outstanding! Thanks this gives me a start. Share this post Link to post Share on other sites
peter lena 9,993 #4 Posted June 1, 2024 @bardern while you are snooping around on any wiring , go slow and easy , chances are very good there is related , cracked / chafed / corroded wiring . verify and go , to every connection . personally regularly re route , and cable wrap numerous areas , also tie wrap in a much smoother lay out point , safety switches and cracked , shorted wiring are a regular thing , alligator clip test wires , will allow you to verify a run . then improve it . pete Share this post Link to post Share on other sites
bardern 0 #5 Posted June 1, 2024 Excellent advice that I will follow. I figured I was in for a time when there were brake pads welded to the pto friction plate lol Share this post Link to post Share on other sites
