WH1618speed 542 #1 Posted May 28, 2024 We recently had this K341 rebuilt, and it runs really rough. I have tried resetting and gapping the points, cleaning them, and swapping them with points of a good-running K341 and a new one. I tried adjusting the carb by backing out the high idle 2 turns and the low 1 3/4 turns. (its not a Walbro). Tried a new spark plug. The only thing I haven't done yet is swapped carbs. I am wondering if when it was rebuilt, it wasn't timed correctly. It sounds like a misfire but it is very consistent at sparking the fuel at the wrong time. It gets really bad at low idle and almost dies. Gets better with an increase in throttle. Also using fresh no ethanol 90 octane gas. Any ideas or thoughts would be great. Thanks! 1 Share this post Link to post Share on other sites
Fordiesel69 271 #2 Posted May 28, 2024 1. did you get the crank timed correctly to the camshaft? 2. are the vales good, and are they adjusted correctly? 3. do you have a temporary ground ties to the engine block ( on a bare spot) so that your ign system is operating correctly? 4 Share this post Link to post Share on other sites
kpinnc 17,150 #3 Posted May 28, 2024 Try a new condenser just for giggles, and make sure the clip grounds well. They can make an engine run really rough. 4 Share this post Link to post Share on other sites
WH1618speed 542 #4 Posted May 28, 2024 (edited) 1 hour ago, Fordiesel69 said: 1. did you get the crank timed correctly to the camshaft? 2. are the vales good, and are they adjusted correctly? 3. do you have a temporary ground ties to the engine block ( on a bare spot) so that your ign system is operating correctly? I didn’t do the rebuild so I am not sure what was done. Valves were supposed to be adjusted to spec Edited May 28, 2024 by WH1618speed 1 Share this post Link to post Share on other sites
WHX?? 54,959 #5 Posted May 28, 2024 1 hour ago, Fordiesel69 said: did you get the crank timed correctly to the camshaft? Guys gotta wonder then if not off a tooth since you didn't set it. Done it myself once... Guessing you tried the points a couple thousand either side of .020? Maybe try static timing? 2 Share this post Link to post Share on other sites
Pullstart 68,880 #6 Posted May 28, 2024 Maybe get the engine builder involved? 2 Share this post Link to post Share on other sites
953 nut 64,109 #7 Posted May 28, 2024 With a battery ignition system, the ignition points are closed the majority of the time. With the points closed and the ignition switch ON the primary windings of the ignition coil have current flowing through them and are developing a magnetic field in the iron core of the ignition coil. The moment the ignition points open the magnetic field collapses and induces a momentary high voltage pulse in the secondary windings of the coil which goes through the spark plug wire and arcs across the gap of the spark plug. If this occurs in the presence of a compressed fuel/air mixture of the proper ratio an explosion will occur within the cylinder. If this explosion occurs at the proper time in the engine’s cycle there will be pressure applied to the piston forcing it downward on the power stroke. The ignition points will continue to open further after this has occurred. How far they open is immaterial, their work has been done for that cycle of engine operation. What is important is when they open relative to the position of the piston on its compression/power revolution. If it occurs too soon there will be backfiring, too late and there will be a reduction of power. In the case of our Kohler engines the sweet spot is twenty degrees Before Top Dead Center, that is what the “SP” mark on the flywheel is set. At the moment the points open the condenser quenches the arc across the points extending their life, the rest of the time it just sits there. Static timing can be done with Kohler engines that do not have a Spark Advance camshaft. The instructions in the Kohler Engine Service Manual for static timing of the later ACR camshaft engines calls for an Ohm Meter to be used. I prefer a 12 Volt Test Light. The light will be connected between the battery “+” terminal and the lead that connects the points to the coil (disconnected from the coil). When the points are closed the light will be on, the moment the points open the light will go off. You don’t have to be focused on it like you would on a meter. With the test light situated near the sight hole for the flywheel (spark plug out so the engine will turn with ease), turn the flywheel slowly by hand in the clockwise direction (counter-clockwise if on the PTO end) until the moment the light goes out. If the “SP” mark is centered in the hole you are done, if not you have a little work to do. If the points are opening too late, they need to be opened further, if it occurs too early they need to be closed up some. Make gradual adjustments until the “SP” mark on the flywheel is centered in the sight hole at the moment the light goes out. Now tighten the screw securely and turn the engine over several revolutions to be sure the points are consistently opening at the proper moment. 5 2 Share this post Link to post Share on other sites
peter lena 9,764 #8 Posted May 28, 2024 @WH1618speed regularly use , BOLT ON ELECTRICAL LUGS , on my engine / frame to battery ground point , never count on the AIR COOLING TINS to carry a ground , ant rusty point will limit current , also use a dielectric lube on threading , also helps headlight grounding , pete 2 Share this post Link to post Share on other sites
WH1618speed 542 #9 Posted May 28, 2024 11 hours ago, WHX?? said: Guys gotta wonder then if not off a tooth since you didn't set it. Done it myself once... Guessing you tried the points a couple thousand either side of .020? Maybe try static timing? Yep I tried that, and points off of one than ran good. Share this post Link to post Share on other sites
WH1618speed 542 #10 Posted May 28, 2024 4 hours ago, 953 nut said: With a battery ignition system, the ignition points are closed the majority of the time. With the points closed and the ignition switch ON the primary windings of the ignition coil have current flowing through them and are developing a magnetic field in the iron core of the ignition coil. The moment the ignition points open the magnetic field collapses and induces a momentary high voltage pulse in the secondary windings of the coil which goes through the spark plug wire and arcs across the gap of the spark plug. If this occurs in the presence of a compressed fuel/air mixture of the proper ratio an explosion will occur within the cylinder. If this explosion occurs at the proper time in the engine’s cycle there will be pressure applied to the piston forcing it downward on the power stroke. The ignition points will continue to open further after this has occurred. How far they open is immaterial, their work has been done for that cycle of engine operation. What is important is when they open relative to the position of the piston on its compression/power revolution. If it occurs too soon there will be backfiring, too late and there will be a reduction of power. In the case of our Kohler engines the sweet spot is twenty degrees Before Top Dead Center, that is what the “SP” mark on the flywheel is set. At the moment the points open the condenser quenches the arc across the points extending their life, the rest of the time it just sits there. Static timing can be done with Kohler engines that do not have a Spark Advance camshaft. The instructions in the Kohler Engine Service Manual for static timing of the later ACR camshaft engines calls for an Ohm Meter to be used. I prefer a 12 Volt Test Light. The light will be connected between the battery “+” terminal and the lead that connects the points to the coil (disconnected from the coil). When the points are closed the light will be on, the moment the points open the light will go off. You don’t have to be focused on it like you would on a meter. With the test light situated near the sight hole for the flywheel (spark plug out so the engine will turn with ease), turn the flywheel slowly by hand in the clockwise direction (counter-clockwise if on the PTO end) until the moment the light goes out. If the “SP” mark is centered in the hole you are done, if not you have a little work to do. If the points are opening too late, they need to be opened further, if it occurs too early they need to be closed up some. Make gradual adjustments until the “SP” mark on the flywheel is centered in the sight hole at the moment the light goes out. Now tighten the screw securely and turn the engine over several revolutions to be sure the points are consistently opening at the proper moment. Really helpful, Thanks! Share this post Link to post Share on other sites
rmaynard 16,866 #11 Posted May 28, 2024 (edited) And I might add, if you have lined up the crank and cam properly, the SP or S mark will be in the right place when the points, set to .020, open. If the SP or S mark is way off, you may have assembled the engine wrong. Also, don't make the mistake of rotating the engine in the wrong direction. Checking the timing must be done rotating the engine in the clockwise direction if viewing from the flywheel side, or counter-clockwise rotating from the PTO side. Edited May 28, 2024 by rmaynard 5 Share this post Link to post Share on other sites
