marreque 214 #1 Posted May 27, 2024 Looking to see if anyone has an answer, my k241 has shorted out 2 spark plugs in the last year. Anyone else have this issue?? Share this post Link to post Share on other sites
WHX?? 53,369 #2 Posted May 27, 2024 I guess I never heard of a plug shorting out. Fouling out yes. A pic of the plug will tell us how the motor is burning fuel. Proper plug? Should be a H-10 champion or equal. Not overheating cooling fins clean? 1 Share this post Link to post Share on other sites
Handy Don 15,249 #3 Posted May 27, 2024 2 minutes ago, WHX?? said: I guess I never heard of a plug shorting out. Fouling out yes. A pic of the plug will tell us how the motor is burning fuel. Proper plug? Should be a H-10 champion or equal. Not overheating cooling fins clean? Any smoke at start or under load? Black or white? 1 Share this post Link to post Share on other sites
953 nut 63,096 #4 Posted May 27, 2024 Check the gap of your ignition points, it should be 0.020" If the gap is not correct yout ignition timing will be off and may result in poor performance and carbon build-up. 1 Share this post Link to post Share on other sites
marreque 214 #5 Posted May 27, 2024 (edited) Not fouled but complete loss of spark at the plug. Second H10 in 6 months. Change the plug and spark is restored. The first plug was probably 30yrs old and I understand that, but the second is a few months. I’ll post a picture of the plug later. Edited May 27, 2024 by marreque Share this post Link to post Share on other sites
marreque 214 #6 Posted May 27, 2024 12 hours ago, Handy Don said: Any smoke at start or under load? Black or white? She doesn’t really smoke to much after warming up. Its original engine and carburetor and really haven’t been touched. Amazing how it still runs as good as it does 59yrs old 4 Share this post Link to post Share on other sites
marreque 214 #7 Posted May 27, 2024 12 hours ago, Handy Don said: Any smoke at start or under load? Black or white? Yes H10 and no overheating. Share this post Link to post Share on other sites
Handy Don 15,249 #8 Posted May 27, 2024 A puff of black smoke at start could be from choking. More and the mixture is too rich. Blue/white smoke is burning oil--not conducive to long plug life. A mismatched plug could be in the wrong heat range and would work poorly or fail after working for a while. 1 Share this post Link to post Share on other sites
Pullstart 68,534 #9 Posted May 27, 2024 9 hours ago, marreque said: Not fouled but complete loss of spark at the plug. Second H10 in 6 months. Change the plug and spark is restored. The first plug was probably 30yrs old and I understand that, but the second is a few months. I’ll post a picture of the plug later. Sometimes, they don’t make ‘em like they used to,.. 6 Share this post Link to post Share on other sites
WHX?? 53,369 #10 Posted May 28, 2024 (edited) 4 hours ago, Pullstart said: Sometimes, they don’t make ‘em like they used to,.. Especially with Chumponions. Some guys here don't like them & prefer Autolites. Personally I have never had issues with Chumps. mismatched plug could be in the wrong heat range Says he is using H 10s. Edited May 28, 2024 by WHX?? 1 Share this post Link to post Share on other sites
marreque 214 #11 Posted May 28, 2024 Well I might as well try an Autolite, maybe it will keep it lit. Anyone know the plug number in Autolite? Share this post Link to post Share on other sites
Fordiesel69 271 #12 Posted May 31, 2024 It outta lite but it don't. Share this post Link to post Share on other sites
rmaynard 16,700 #13 Posted May 31, 2024 On 5/28/2024 at 4:57 PM, marreque said: Anyone know the plug number in Autolite? Autolite 216 Share this post Link to post Share on other sites
Wheelhorse#1 1,890 #14 Posted June 1, 2024 Check the points .I had a similar issue and found the points were cracked.And they were original kohler. 1 Share this post Link to post Share on other sites
marreque 214 #15 Posted June 3, 2024 On 5/31/2024 at 9:21 AM, rmaynard said: Autolite 216 Thank you Share this post Link to post Share on other sites
marreque 214 #16 Posted June 14, 2024 Just put a fresh Autolite 216 in the Horse. Fired right up, now to see how long it will last. Thank you gentlemen! 2 Share this post Link to post Share on other sites
