Jim Sheaffer 11 #1 Posted May 23, 2024 Sorry folks that I have to do this, but I've got an older 42in side discharge deck with aluminum Double D spindles on it. I have no idea of the model or serial numbers of this deck either. Two of the three spindles have grease fittings on them, one does not. The one without has indications the bearing is starting to fail. Before it tears up the shaft, could someone help ID the captured needle bearing and the ball bearing for me. Thank you very much guys. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,017 #2 Posted May 23, 2024 Here is a list of the decks in the order they were produced. If you go into our Files and do a search for a model number the pages from the spindle identification charts have been added to each model file. Nothing to download. Just click on the small pictures to enlarge them. Mower DNA 1966-1967 model RL-426 replaced by 1968 model 5-1421 1969 model 5-1422 1970 model 5-1423 1971 model 5-1000 1971-1972 model 5-1001 1973-1974 model 5-1010 1975 model 5-1011 1975 model 5-1012 1976 model 65-42MS01 - Online Toro parts illustration is the 48" SD deck 1976 model 65-42MS02 - Online Toro parts illustration is the 48" SD deck 1977 model 75-42MS01 - These 42" side discharge decks all use blades with 5/8" x 3/4" double-D center hole unless the spindles have been upgraded (Do not have operator manual) -------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- These decks all use blades with a 3/4" center hole. 1977 model 75-42MS02 replaced by (Do not have operator manual) 1978 model 85-42MS01 (Do not have operator manual) 1979 model 95-42MS00 (Do not have operator manual) 1979 model 95-42MS01 (Do not have operator manual) 1980 model 05-42MS01 (Have operator manual) 1981-1983 model 05-42MS02 1984 model 05-42MS03 - Last year for bearings with 3/4" ID 1985 model 05-42MS04 - First year for bearings with 17mm ID unless older spindles were updated. 1986-1988 model 05-42MS05 1989 model 15-42SC01 1990 model 15-42SC02 1990-1992 model 15-42SC03 1993-2007 and 2009-2012 model 78345 - These decks all use blades with a 3/4" center hole. Note - 17mm is .669" 1 Share this post Link to post Share on other sites
peter lena 9,782 #3 Posted May 24, 2024 @Jim Sheaffer what ever those bearings are perfect opportunity to remove the grease side shields and re grease them , use the lucas green chassis grease , xtra hd 550 deg flash point , they have the rubber side shields , use a small flat putty knife or small flat pocket screwdriver , carefully remove both shields , wipe out original grease , carb cleaner for flush , repack to same amount , and press seals in place , no whyining noise , solid smooth / quiet . have that set up on my 3 decks , no whyining , bearing noise , really makes a difference . you can also do the same thing to the 4 mule drive bearings , PTO drive , inner needle bearing , replace the outer sealed cone bearing , napa has it . you can even snug up the pto sloppy lever , if interested . pete Share this post Link to post Share on other sites
