bkarp@roadrunner.com 6 #1 Posted May 22, 2024 Has anyone heard of engine oil leaking out of the carb. throttle opening with m12s kohler engine running,spark plug is clean. This makes no sense to me. Oil level in engine is not over filled. Share this post Link to post Share on other sites
953 nut 70,659 #2 Posted May 22, 2024 Kohler Magnums have a "pollution control" tube from the valve cover to the air intake of the breather rather than a crankcase vent. If you have worn piston rings resulting in blowby the pressure in the crankcase would cary oil vapors to the air cleaner housing. Doing a leak-down test will let you know where the problems are. 1 2 Share this post Link to post Share on other sites
bkarp@roadrunner.com 6 #3 Posted May 22, 2024 thanks for the help, it has been burning more oil lately,i thought that could be the problem,going to look for a small engine rebuilder. Share this post Link to post Share on other sites
wallfish 20,744 #4 Posted May 23, 2024 @Sparky See Dick's post. Is that the smoke you are seeing? From the case vapor tube? 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,898 #5 Posted May 23, 2024 8 hours ago, wallfish said: @Sparky See Dick's post. Is that the smoke you are seeing? From the case vapor tube? Seems to be coming from the carb…but I’ll fire it up tomorrow and look closer. 2 Share this post Link to post Share on other sites
