JBro72 0 #1 Posted May 21, 2024 Hello. I recently acquired a 1966 WH 656. It has a 3 groove pulley on the engine, however, the groove that the drive belt runs in is bent. Would anyone happen to have a P/N or one laying around that they are willing to part with? Thanks in advance. Jeff Share this post Link to post Share on other sites
Pullstart 68,624 #2 Posted May 22, 2024 you should be posting this in the classifieds section of the forum. Share this post Link to post Share on other sites
wallfish 18,857 #3 Posted May 22, 2024 Do you use the outer groove? Can it be flipped around? I forget what the 3 pulley looks like off hand but thinking those grooves are all the same size. Probably damaged trying to get it off. Is it off now? 1 Share this post Link to post Share on other sites
Ed Kennell 44,093 #4 Posted May 22, 2024 to the Jeff. Share this post Link to post Share on other sites
Pullstart 68,624 #5 Posted May 22, 2024 1 hour ago, wallfish said: Do you use the outer groove? Can it be flipped around? I forget what the 3 pulley looks like off hand but thinking those grooves are all the same size. Probably damaged trying to get it off. Is it off now? there are two on the outside and one inside of the set screw, I do believe. I generally use the outer grove on the PTO anyway, so it should work, for now, in theory Share this post Link to post Share on other sites
Terry M-(Moderator) 2,283 #6 Posted May 22, 2024 6 hours ago, Pullstart said: you should be posting this in the classifieds section of the forum. Copied this to the Classifieds.. Share this post Link to post Share on other sites
JBro72 0 #8 Posted May 24, 2024 On 5/21/2024 at 8:07 PM, wallfish said: Do you use the outer groove? Can it be flipped around? I forget what the 3 pulley looks like off hand but thinking those grooves are all the same size. Probably damaged trying to get it off. Is it off now? It uses the inner groove for the drive belt. I tried flipping it but it seems to have a taper. It wouldn't go. Share this post Link to post Share on other sites
JBro72 0 #9 Posted May 24, 2024 On 5/22/2024 at 7:42 AM, rjg854 said: Jeff Thank you Share this post Link to post Share on other sites
JBro72 0 #10 Posted May 24, 2024 On 5/21/2024 at 8:07 PM, wallfish said: Do you use the outer groove? Can it be flipped around? I forget what the 3 pulley looks like off hand but thinking those grooves are all the same size. Probably damaged trying to get it off. Is it off now? It is off. The old engine and all parts were in a box. It appears to have been damaged getting it off. Share this post Link to post Share on other sites
JBro72 0 #11 Posted May 24, 2024 On 5/22/2024 at 1:54 AM, Terry M said: Copied this to the Classifieds.. Thank you sir Share this post Link to post Share on other sites
