JoeB 34 #1 Posted May 14, 2024 (edited) When I turn the ignition key on my 312H often nothing happens, but if I quickly turn the lights off and on while turning the ignition key the starter engages. Any ideas? Thanks Edited May 14, 2024 by JoeB Share this post Link to post Share on other sites
oliver2-44 11,758 #2 Posted May 14, 2024 Possible a faulty key switch. The additional current from the lights is helping bridge across a dirty/worn contact 1 Share this post Link to post Share on other sites
953 nut 69,543 #3 Posted May 14, 2024 24 minutes ago, oliver2-44 said: Possible a faulty key switch. The additional current from the lights is helping bridge across a dirty/worn contact Also could be some corrosion in a fuse holder or any connection that "Warms Up" with the little bit of electrical flow the lights bring on. Share this post Link to post Share on other sites
Ed Kennell 47,399 #4 Posted May 14, 2024 Try cleaning the 25amp fuse holder. Share this post Link to post Share on other sites
