Retired Wrencher 6,921 #1 Posted May 13, 2024 I have a c81 was just wondering if those solid mounts are still available? If not does any one know the Part # Thanks in advance. Share this post Link to post Share on other sites
ebinmaine 80,285 #2 Posted May 13, 2024 Zach Kerber sells them. Share this post Link to post Share on other sites
Retired Wrencher 6,921 #3 Posted May 13, 2024 18 minutes ago, ebinmaine said: Zach Kerber sells them. Thanks Eric I just sent him a message if he will make more. Listed as last set. Not bad for $60. 1 Share this post Link to post Share on other sites
ri702bill 12,816 #4 Posted May 13, 2024 (edited) And they work just fine.... loosen the rear triangular block on the frame to allow installation... Edited May 13, 2024 by ri702bill 4 Share this post Link to post Share on other sites
Retired Wrencher 6,921 #5 Posted May 13, 2024 @ri702bill Thanks for the info. Looks easy enuf. 2 Share this post Link to post Share on other sites
Achto 32,347 #6 Posted May 13, 2024 Lowell has the solid mounts as well. https://wheelhorsepartsandmore.com/product/engine-mounts-for-wheel-horse/ 2 Share this post Link to post Share on other sites
Retired Wrencher 6,921 #7 Posted May 13, 2024 8 minutes ago, Achto said: Lowell has the solid mounts as well. https://wheelhorsepartsandmore.com/product/engine-mounts-for-wheel-horse/ Thank you Achto. 2 Share this post Link to post Share on other sites
JoeM 10,156 #8 Posted May 13, 2024 A budget friendly set can be made from 1/2 bar stock. 2 2 Share this post Link to post Share on other sites
John2189 599 #9 Posted May 13, 2024 What is the reasoning for the solid mounts? Share this post Link to post Share on other sites
Fordiesel69 272 #10 Posted May 13, 2024 The rubber dry rots, or it gets soft from oil, and then the engine hops around like a pregnant rabbit. 3 Share this post Link to post Share on other sites
ri702bill 12,816 #11 Posted May 13, 2024 John - my C81 is 45 years old, the rubber isloator portion of all 4 mounts was badly deteriorated, That allowed a lot of engine shake and the engine would visibly shift with the PTO engaged. Not anymore... 2 Share this post Link to post Share on other sites
Retired Wrencher 6,921 #12 Posted May 13, 2024 5 hours ago, JoeM said: A budget friendly set can be made from 1/2 bar stock. Joe I like that set up big washer in the center 3/8” bolt tap it in to the plate. I have some flat rubber 1/4” think might help with vibration? Share this post Link to post Share on other sites
ri702bill 12,816 #13 Posted May 13, 2024 Hmmm... the idea is to go Solid - no rubber. (It works....) 1 Share this post Link to post Share on other sites
ebinmaine 80,285 #14 Posted May 13, 2024 4 hours ago, Retired Wrencher said: Joe I like that set up big washer in the center 3/8” bolt tap it in to the plate. I have some flat rubber 1/4” think might help with vibration? Go steel Gary. All solid. Keep the rubber right out. You'll be happy you did. 🙂 7 hours ago, Fordiesel69 said: hops around like a pregnant rabbit. Seems to me that's a fair amount of hops!! 1 2 Share this post Link to post Share on other sites
John2189 599 #15 Posted May 14, 2024 10 hours ago, ri702bill said: John - my C81 is 45 years old, the rubber isloator portion of all 4 mounts was badly deteriorated, That allowed a lot of engine shake and the engine would visibly shift with the PTO engaged. Not anymore... Ok my c165 shakes a bit too Share this post Link to post Share on other sites
