D_Mac 9,339 #1 Posted May 4, 2024 (edited) Looking at one but according to the owner it won't move. Not sure if he even tried the release valve or if it is stuck. Been setting for a couple years. Manual lift not hydro. Thoughts on what I should look for if I go see it. Also where is the release valve on this model? Edited May 4, 2024 by D_Mac Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,505 #2 Posted May 4, 2024 1 1 Share this post Link to post Share on other sites
Ed Kennell 47,554 #3 Posted May 4, 2024 9 minutes ago, D_Mac said: Looking at one but according to the owner it won't move. Not sure if he even tried the release valve or if it is stuck. Been setting for a couple years. Manual lift not hydro. Thoughts on what I should look for if I go see it. Also where is the release valve on this model? The 312A with manual lift has the Eaton 700 hydro. There is no tow release valve on the Eatons and the 700 is nearly impossible to move. Best to put it on a dolly till you can get the engine running. You may be able to hand push it by jiggling the motion control lever around the nuetral position. Do not tow or push with power. 2 1 Share this post Link to post Share on other sites
Pullstart 71,350 #4 Posted May 4, 2024 If the tires are up, I like to take advantage of an open differential. Give the tractor some left to right pressure and spin one rear wheel backwards while pushing it forward. The spider gears will allow it to propel the chosen direction with no transmission movement.,, 1 Share this post Link to post Share on other sites
953 nut 69,726 #5 Posted May 4, 2024 If you have a two wheel hand truck you can put it under the rear end and pick up the transaxle then hold it down while someone pushes it backward. Had to do this with one that was locked up because of a broken differential bolt. 1 1 1 Share this post Link to post Share on other sites
D_Mac 9,339 #6 Posted May 4, 2024 So it's my understanding that you can't push it around without engine running? There is no dump valve like on my 1075 and 875 ? 2 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,505 #7 Posted May 5, 2024 Pushing instructions are on page 7 of the operator manual. Tried to copy and paste but can't make it work. 1 Share this post Link to post Share on other sites
953 nut 69,726 #8 Posted May 5, 2024 9 hours ago, gwest_ca said: Pushing instructions are on page 7 of the operator manual. Tried to copy and paste but can't make it work. Are you sure this is for the Eaton 700 transaxle? 1 Share this post Link to post Share on other sites
Ed Kennell 47,554 #9 Posted May 5, 2024 12 hours ago, D_Mac said: There is no dump valve like on my 1075 and 875 ? Correct, the Sundstrands have a "dump" valve and the Eatons do not. With the dump valve open, the Sundstrands can be safely towed. The Eatons can not be safely towed. The Eaton 1100 can be pushed by hand. Some of the Eaton 700s may be slowly pushed by hand by jiggling the motion control lever. Some Eaton 700s will not move at all. You have an Eaton 700. Best to pick it up to move it. 2 1 1 Share this post Link to post Share on other sites
Handy Don 17,547 #10 Posted May 5, 2024 11 hours ago, Ed Kennell said: You have an Eaton 700. Best to pick it up to move it. Looked at another way, if you can easily hand push a 700, it is probably broken. 2 Share this post Link to post Share on other sites
D_Mac 9,339 #11 Posted May 6, 2024 Talked to the owner of it again today. He told me that it stopped moving when the engine was running. That pretty much made me loose interest in it. 1 Share this post Link to post Share on other sites
953 nut 69,726 #12 Posted May 6, 2024 11 hours ago, D_Mac said: it stopped moving when the engine was running. Could be the belt broke. 1 Share this post Link to post Share on other sites
Handy Don 17,547 #13 Posted May 6, 2024 12 hours ago, D_Mac said: Talked to the owner of it again today. He told me that it stopped moving when the engine was running. That pretty much made me loose interest in it. Changes the menu for sure, and one has to gauge one’s appetite! 1 Share this post Link to post Share on other sites
D_Mac 9,339 #14 Posted May 6, 2024 Not sure what it can be. Plus I'm no mechanic. Share this post Link to post Share on other sites
Ed Kennell 47,554 #15 Posted May 6, 2024 2 hours ago, D_Mac said: Not sure what it can be. Plus I'm no mechanic. Broken spring on drive belt tensioner. Broken belt. Loose pulley on tranny input shaft. Low oil . 1 Share this post Link to post Share on other sites
Ed Kennell 47,554 #16 Posted May 7, 2024 Oh, one more a loose axle spinning in a hub. Share this post Link to post Share on other sites
Tuneup 1,459 #17 Posted May 11, 2024 'Doesn't move anymore with engine running'. Sounds like it would be a screaming deal and an easy fix. Unusual to find these burned up but expected that they'd all be worn. 15W-50 fixed mine up nicely and is the recommended lubricant by a builder or two (yeah, internet but worked well here). I'm glad I'm not in the northeast where these things are more common. My shed would have to start having levels of storage. 4 is enough (for now) and the 516H just goes and goes. Share this post Link to post Share on other sites
Easton Rich 1,263 #18 Posted May 23, 2024 Get it, as some of these guys know I’ve looked at sooooooo many good deals and let them go because of little things Share this post Link to post Share on other sites
squonk 48,207 #19 Posted May 23, 2024 Eaton 700's are a weak hydro. It's a crap shoot finding a good used one. Share this post Link to post Share on other sites
