JimSraj 566 #1 Posted May 2, 2024 Anyone know the specs on the gas cylinder (78-3240) for the drive belt tension pulley on a ‘93 310-8? Share this post Link to post Share on other sites
JoeM 9,642 #2 Posted May 2, 2024 Might want to check with these folks, they may help with a reasonable price Share this post Link to post Share on other sites
JimSraj 566 #3 Posted May 3, 2024 Thanks Joe! I will call them tomorrow. Since I posted I found out that AZ tractor has an aftermarket. Calling Lincoln tomorrow as well. Also thinking of just putting a spring on it. 2 Share this post Link to post Share on other sites
Lee1977 7,566 #4 Posted May 3, 2024 (edited) Most of us just take them off and use the spring like the older models. Edited May 3, 2024 by Lee1977 5 Share this post Link to post Share on other sites
Pullstart 68,932 #5 Posted May 3, 2024 @JimSraj you’d be better off just installing a spring. Share this post Link to post Share on other sites
Bill D 2,604 #6 Posted May 3, 2024 If you put a spring on it you may want to add a dampener that was also found in the older models. I did that on my 312-8 and it made the tractor much less jumpy. Share this post Link to post Share on other sites
JimSraj 566 #7 Posted May 3, 2024 5 minutes ago, Bill D said: If you put a spring on it you may want to add a dampener that was also found in the older models. I did that on my 312-8 and it made the tractor much less jumpy. Ive got it apart now and will be putting a spring on today. Do you have any pictures of that dampener installed? Share this post Link to post Share on other sites
Bill D 2,604 #8 Posted May 4, 2024 22 hours ago, JimSraj said: Ive got it apart now and will be putting a spring on today. Do you have any pictures of that dampener installed? I don't. Maybe someone else does. I maybe able to get one later if I remember. Share this post Link to post Share on other sites
