canam1991 2 #1 Posted August 28, 2009 :ychain: this morning i go out in the garage and the is a gas leak on the floor so i pull the tank a the right side or the tank is leaking out a bunch of pin holes. The left side the spot welds holding the studs on pulled off so she's a leaker does anyone have one? :hide: Share this post Link to post Share on other sites
MikesRJ 558 #2 Posted August 29, 2009 Depending on the material of the tank and the size of the holes, the tank can be repaired. A motorcycle repair kit (such as POR-15) is pretty simple to do and under $50. If the tank is steel that is probably your best bet. See these links for an explaination; POR-15 Instructions POR-15 Supplier Share this post Link to post Share on other sites
