bardern 0 #1 Posted May 1, 2024 Hi new to the forum and WH tractors My experience has been in IH cub cadets zero experience with WH. I just picked up a 418a and inhave issues with ground speed. The tractor will not hold speed it will speed up on its own to the point where it is full speed. Where is the best place to start to work out the issue? Thanks all Share this post Link to post Share on other sites
Ed Kennell 44,992 #2 Posted May 1, 2024 to the Please post the model number of your tractor so we can find the correct manual . Share this post Link to post Share on other sites
pfrederi 19,940 #3 Posted May 1, 2024 You have an Eaton 1100 very good hydro unit. Is the motion control lever moving backwards as you lose speed or does it stay still and tractor slows down? Share this post Link to post Share on other sites
bardern 0 #5 Posted May 1, 2024 2 hours ago, Ed Kennell said: That is exactally what I need thanks! Tomorrow i am going to pull the tins off and see what is going on in there. This tractor will be a learning curve from my wide frame cubs. Share this post Link to post Share on other sites
